While motor is out, What should I change?
OT: so what happend with you and PrecisionH23a???
because he stickied that thread about the bad shipping on the side skirts right on the TOP of the prelude forum
Modified by BS 22 at 12:36 AM 12/5/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 »</TD></TR><TR><TD CLASS="quote">OT: so what happend with you and PrecisionH23a???
Modified by BS 22 at 12:36 AM 12/5/2004</TD></TR></TABLE>
preciscion hasnt been on, so i dunno whats going on....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boarderx192 »</TD></TR><TR><TD CLASS="quote">I am swapping a JDM H22 into my 5th gen. While the motor is out, what should I replace?</TD></TR></TABLE>
performance clucth and lightweight flywheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">crank seal, cam seals, water pump, timing belt, acc belts, valve cover gasket, oil pan gasket, dist o ring, and a lot more</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 »</TD></TR><TR><TD CLASS="quote">
performance clucth and lightweight flywheel.</TD></TR></TABLE>
These are the things I changed.
I also swapped to a manual timing belt tensioner and installed a Hondata intake manifold gasket. I also COMPLETELY cleaned out my intake manifold while it was off.
All gaskets and seals, clutch and flywheel, belts, water pump, manual tensioner swap. Basically everything you have $ for. The more you do while the motors out the longer you will run leak and problem free.
Honda does sell top and bottomend kits with all the gaskets you need
Mike VR6
35
Mar 2, 2007 03:23 AM
TRE_
May 3, 2006 06:32 AM
Fuster_Cluck
Feb 27, 2003 07:26 AM
