energy susp. red or black?
Old Dec 4, 2004 | 08:38 PM
ice11honda's Avatar
Default energy susp. red or black?
I am going to get the hyperflex kit for a 96 hatch, but I was wondering (search gave me nothing) which ones are better. The black ones which are apparently self-lubricating, or the red ones which are said to not be selflubricated. Can anyone confirm this, and which would be my best choice. I have very stiff spring rates and not looking forward to the squeaks. Are both the same in stiffness? Thx
Old Dec 4, 2004 | 09:26 PM
rice_classic's Avatar
Default Re: energy susp. red or black? (ice11honda)
You ask good questions and since you said you searched I will help.
I have the hyperflex kit on my daily driver and they NEVER squeak, I will teach you my secret.
1st point of business though, get the red ones. From what I understand there is something in the black ones that is used to make them black that will allow them to deteriorate, rip, or crumble. The red ones yield no problems. My bushings have seen 40k miles inluding 1 season autocrossing and 6 open track days along with many "spirited drives".
2nd point, lubrication and squeeking. Here is a link that will be VERY valuable to you: http://overboost.com/story.asp?id=426 Scroll about half way down the page and it will show you how to install Zerk fittings (grease fittings) into the lower control arms and rear trailing arms so that they are easy to re-lube. As for the rear LCA's you will not install a zerk fitting but you might want to take off the control arm no more than once a year and re-lube them if necessary (I haven't had to yet and it's been 40k miles in 2.5 years.)
Good luck.
Old Dec 4, 2004 | 09:27 PM
Default Re: energy susp. red or black? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">use red for autox. black works best for road racing.</TD></TR></TABLE>
I've never ever heard this, I want more info on this.
Old Dec 4, 2004 | 10:36 PM
B HATCH's Avatar
Default Re: energy susp. red or black? (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">and 6 open track days along with many "spirited drives".
Good luck.</TD></TR></TABLE>
mmmmm i am wondering if i should do this grease nipple thing. i have all my new bushings all lubed up and ready for installation..... i would have to take all the new bushigns out of the spare donner control arms and then find nipple and drill and tap...and then intall again.
Old Dec 5, 2004 | 07:29 AM
sleeping GIANT's Avatar
Default Re: energy susp. red or black? (B HATCH)
I have the black ones on my coupe 30k on them so far w/ no prob. deff. a big difference in handling. takes a little while to install them.
Old Dec 5, 2004 | 12:41 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
black is sleeper.
when you install the master kit, a propane torch and a dremel make the job A LOT easier. burn/scrape the rubber out with the torch and a flathead, pull out the inner sleeves with some needle nose pliers, and finally cut out the outer sleeve with the dremel and a grinding tip.
ludesrv
Jan 28, 2007 09:35 AM
DeDonDeRosa
Suspension & Brakes
16
Jan 12, 2006 10:17 AM
Nothing.Special
Sep 6, 2003 06:01 PM
uszcrx
Apr 3, 2003 02:32 PM
