Stock Fuel pressure
Does anyone know what the stock fuel pressure is for a B18C1? I believe I read it was around 48-52 somewhere on TI.
What the real concern is when should it read what it is supposed to read? With the vacuum line on or off? Also when it is off should you cover the line with you finger so there is no vacuum leak to get the reading or read it with the vacuum leak created by removing the line?
I hope this is worded ok.
