Vtec poping with no vtec computer
Old Dec 4, 2004 | 04:03 PM
DsBananas94LS's Avatar
Default Vtec poping with no vtec computer
would vtec pop with a MSD RPM activated switch that is ran from the vtec soilenoid to a non vtec computer
Old Dec 4, 2004 | 05:14 PM
mugenracer's Avatar
it should work with any 12v feed hooked to any switch
Old Dec 4, 2004 | 05:20 PM
BlueIntegraBoy's Avatar
Default Re: (mugenracer)
My friend disconnected his solenoid and ran a switch to it. The car went into limp mode.
Old Dec 5, 2004 | 06:48 PM
92hb's Avatar
Default Re: (BlueIntegraBoy)
Yep the ecu is looking for a ohm setting I think if you disconnect the vtec plug it pops the check light to
Old Dec 5, 2004 | 07:49 PM
m R g S r's Avatar
Default Re: Vtec poping with no vtec computer (DsBananas94LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsBananas94LS &raquo;</TD></TR><TR><TD CLASS="quote">would vtec pop with a MSD RPM activated switch that is ran from the vtec soilenoid to a non vtec computer</TD></TR></TABLE>
That's how a shop over in nanuet wired my friend's LS/VTEC hatch. Fucktards. .
Old Dec 5, 2004 | 07:51 PM
m R g S r's Avatar
Technically it should, because The sending wire to the VTEC solenoid is just a 12v wire, but the fuel and timing maps are probally fucked. Anddd the VTEC computer is going to be looking for alot more **** than just a 12v signal. Speed sensor, oil pressure, temperature, rpm, etc. .
grimald
Nov 16, 2004 01:49 PM
davken1102
Aug 2, 2003 06:01 PM
THE SOUND OF VTEC
Apr 30, 2002 12:20 AM
