The floor jack slipped and now I need help....
Old Jan 1, 2002 | 12:34 PM
shingles's Avatar
Default The floor jack slipped and now I need help....
the "front bulk head"....
The piece that the hood latch is secured onto, and the lower front cross memeber:
The number 5 assembly...
does anyone know if that piece is replaceable at home? Or does it require body shop?
thanks..
-Shing
Old Jan 1, 2002 | 01:12 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: The floor jack slipped and now I need help.... (shingles)
Usually you can just replace #2, lower core support and have the rest pulled into shape.
The pieces, esp. #2 are welded on. Will need a body shop to fix it. I used a cheap gasless mig welder and it did ok.
Old Jan 1, 2002 | 01:18 PM
shingles's Avatar
Default Re: The floor jack slipped and now I need help.... (Mista Bone)
Mr. B,
Thanks for the reply.
Does this in any way effect the way the handling of the car?
thanks,
-Shing
Old Jan 1, 2002 | 01:20 PM
CimorelliCRX's Avatar
Everything in there is fixable at home if you have a welder. Some of the stuff, like 3 6 7 and 8 they just screw to that bottom peice. But the bottom peice needs to be welded on there..
Old Jan 1, 2002 | 01:24 PM
my_slow_civic's Avatar
Wow, great diagram. I need that to go to the dealer.
Old Jan 1, 2002 | 01:31 PM
shingles's Avatar
I was thinking, it would appear that the bottom piece(2) is more for the ac condensor support correct? what if I didn't fix it, will it hurt anything? But instead, just make sure everything else is in place and the hood closes and doesn't fly off etc? Just a thought...
thanks
-Shing
Old Jan 1, 2002 | 04:02 PM
SiR831's Avatar
Default Happened to me
Does your hood close but isn't flush with the fenders? As if everything shifted up? I fixed mines by shifting it (part#2) down with a prybar! After how many tries
[Modified by SiR831, 1:04 AM 1/2/2002]
Old Jan 1, 2002 | 04:04 PM
EP3_05's Avatar
Default Re: Happened to me (SiR831)
Does your hood close but isn't flush with the fenders? As if everything shifted up? I fixed mines by shifting it down with a prybar!
Hahahaha...I had the same thing happen and my hood wouldn't close and everything was out of wack. It wasn't anything a rubber mallet and prybar couldn't fix though. I just tried to see where stuff had been bent and then I just bent it back.
Old Jan 1, 2002 | 05:04 PM
shingles's Avatar
I was lucky in the that hood was already open so #6 didn't get too messed up. mainly #7 and #2 are bent. At this point I can close my hood... but since #2 is pushed up about 1" or so, I can't strap down #7 to #2. The only bad part about this is the hood does close as tightly and it seems like it could push up a little while driving. Since #2 is pushed up so much, I can't pull it back into place. Also both #1 and #4 are bend slightly....
I guess tomorrow I will drive to the body shop. I wonder if I could make sears pay for this... I just looked at the jack again... and it seems to be messed up. I suspect the jack gave way and caused it to slip off of the jack point.
This goes to show, NEVER work with a jack alone... infact I was just in the process of putting in my jack stands.
-Shing
[Modified by shingles, 8:05 PM 1/1/2002]
Old Jan 1, 2002 | 05:13 PM
E-AT_me's Avatar
Default Re: Happened to me (shingles)
i use jack and jackstands..
Old Jan 1, 2002 | 06:26 PM
Mista Bone's Avatar
D Tranny Guru
lower core support and jack point.
JacksonMade
Paint and Body
May 11, 2010 07:39 PM
94dxcivicve
Dec 2, 2006 05:41 PM
Twigster311
Aug 26, 2003 04:48 PM
cbender
Nov 6, 2002 11:43 AM
