clutchmasters stage 4 , soft pedal ???
Old Dec 4, 2004 | 02:53 PM
boosted350z's Avatar
Default clutchmasters stage 4 , soft pedal ???
i just installed a 97 junkyard tranny , and a brand new clutchmasters 4 clutch, and resurfaced the flywheel. I also replaced my master cltuch cylinder(leaking), then i bled the lines properly.
yet my clutch doesn't feel very hard, it's ok , but feels softer than before, and i also had the same clutchmasters 4 clutch before. Why would the clutch feel soft somewhat? also , there are no leaks, master cylinder ok, slave is ok, lines ok, etc...
any help could be appreciated.
Old Dec 4, 2004 | 03:27 PM
boosted k20's Avatar
Default Re: clutchmasters stage 4 , soft pedal ??? (boosted350z)
how did u bleed the system? sounds like u didnt bleed it properly
Old Dec 4, 2004 | 04:44 PM
skunk2eg's Avatar
Default Re: clutchmasters stage 4 , soft pedal ??? (boosted k20)
did you replace the pressure plate?
Old Dec 4, 2004 | 06:28 PM
WhiteGSR95's Avatar
hmm..
probably got air in the system, and did u get a pressure plate? check the linkage might have not been adjusted well.
Old Dec 4, 2004 | 07:44 PM
shorto85's Avatar
Have you replaced the slave cylinder yet?
Old Dec 5, 2004 | 10:32 AM
Default Re: (shorto85)
no , slave cylinder is good.
pressure plate is new.
system is beld properly, im 4 sho' .
Old Dec 5, 2004 | 06:07 PM
honDA16's Avatar
new throwout bearing with the clutch? could not be working properly
jdmcivicferio
Sep 21, 2011 09:07 AM
mouser579
Jan 2, 2009 12:32 PM
jaywo_23
Oct 11, 2007 08:49 PM
macfadyen
Sep 7, 2006 12:00 PM
ViZ
Sep 18, 2003 12:19 PM
