Sea Foam Trans-Clean?! Not SF engine cleaner. Anyone tried it?
While browsing through the new Autozone in my town (YES, AUTOZONE, NOT NAPA.
) I came across Sea-Foam Trans-Clean. Apparently it triples up as a trans/brake system/rack+pinion system flush/cleaner. Directions are simply drop 1/2-1 pint of this into your trans, and drive for 5-10 minutes, making sure to shift into every gear. Then do a fluid change on the trans.
Its supposed to clean gum/tarnish/buildups much like the engine cleaner version. Anyone tried it? Anyone even heard of it? I was just suprised to see the Sea-Foam, because I was under the impression only Napa carried it, no less to see SF Transmission cleaner.
Got some primer/high temp enamel and brake cleaner to clean up my new brake parts for my rear disk swap while I was there.
) I came across Sea-Foam Trans-Clean. Apparently it triples up as a trans/brake system/rack+pinion system flush/cleaner. Directions are simply drop 1/2-1 pint of this into your trans, and drive for 5-10 minutes, making sure to shift into every gear. Then do a fluid change on the trans.Its supposed to clean gum/tarnish/buildups much like the engine cleaner version. Anyone tried it? Anyone even heard of it? I was just suprised to see the Sea-Foam, because I was under the impression only Napa carried it, no less to see SF Transmission cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Yeah it only listed directions for autos, but whose to say it cant go both ways?
The machnisms involved with manual and automatic transmissions are completely different. It will probably work - as in not break anything - but I doubt you'll notice nearly as much of a difference in your manual tranny as you would in an auto.
</TD></TR></TABLE>The machnisms involved with manual and automatic transmissions are completely different. It will probably work - as in not break anything - but I doubt you'll notice nearly as much of a difference in your manual tranny as you would in an auto.
sleepyhamsterlx
Mar 15, 2004 07:15 PM
Powered by Honda
Feb 20, 2002 12:40 PM
