B16a FROM HELL......please help
Old Dec 4, 2004 | 11:19 AM
Bseriescivic5's Avatar
Default B16a FROM HELL......please help
Ok guys, this has been a 4 month swap still in the works...motor is from a wrecked eg hatch, a first gen b16a with hydro tranny. was put in my car and 2 months later finally got it to run...hole in IM, burnt DIzyy, ect ect...you know how it is.... Heres the new problem:
ok got car running pretty decently, no VTEC, but it was running ok, drive the car home and as soon as i get home, i feel a sudden loss of power, come to find out the BELT SLIPPED..... I have no idea how this is possibly happining, new belt, new spring......WTF do you guys have any ideas how the belt could slip when all these parts are new, and only an hour before i put a new belt on tightened to specs, did timing, everything like you are soppose to......really need help thanks.
Old Dec 4, 2004 | 11:20 AM
Update, new tensioner is on the way....however im still sceptical about this working, so more ideas are welcome.
Old Dec 4, 2004 | 11:41 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (Bseriescivic5)
A.) did you torque everything on the timing side of the engine to Helm's specs and are you using an OEM timing belt?
B.) why doesn't VTEC work?
The timing drop due to a slipping belt would certianly explain the loss of power, and I'll be the first to say you're lucky it only jumped a tooth or two and not enough to smash all your valves into your pistons .
Old Dec 6, 2004 | 06:55 AM
everything is teightened to specs... oem timing belt.....vtec doesnt work b/c i have code 6 which is water temp sensor.....and yes i am lucky.......hopefully the new tensioner will solve the problem....other than that, im outta ideas........
Old Dec 6, 2004 | 07:05 AM
hondascientist's Avatar
might want to double check the vtec silinoid! wires might be arking out
Old Dec 6, 2004 | 04:54 PM
not silinoid, i no the vtec problem, i have code 6, im not concerned with that, i need answers on my timing belt issues......vtec isnt going to matter if the belt falls off and i destroy my valves.....
Old Dec 7, 2004 | 07:13 AM
come on gurus im outta ideas....thanks
Old Dec 7, 2004 | 07:33 AM
i think that somthing was not tight or to factory specs if the belt slipped -or you have a 1.8 belt
Old Dec 8, 2004 | 10:01 AM
possibly. I will install a new water pump and a new tensioner and double check all bolts.....this weekend.....belt is def. oem b16a.
thanks.
Old Dec 8, 2004 | 10:18 AM
smart monkey's Avatar
I bet you intalled the belt and did not put the right tension on it. this is usually how most people get a belt to slip. they are not setting up the tensioner in the right manner and or sequence.
Old Dec 10, 2004 | 07:12 AM
I wish that were the problem, but i have installed 2 different belts all to specs......belt will be tight exactly like its soppose to be, then when i drive around town for a while and have a sudden loss of power, i look at the belt and its loose again.
Old Dec 10, 2004 | 07:15 AM
klungemonger's Avatar
Any stripped threads or something? Try some loctite on the tensioner bolt and let it cure before driving it around.
Old Dec 10, 2004 | 07:26 PM
thanks for all the replys guys,,, got VTEC working today.....not coming in real strong cuz of shitty timing but got her to work. still working on timing belt. new tensioner comes in next week, will try the lock tite as well.
Old Dec 10, 2004 | 09:47 PM
31flavorscivic's Avatar
loctite is great... until you have to get something off again. Then it becomes a complete pain in the ***.
Old Dec 12, 2004 | 09:05 AM
new update.....VTEC now works.....was trying to fix the wrong damn sensor....code 6 is water temp, and i was trying to fix the fan switch......DUH....apologues to whoever told me i was wrong in the first place. Did timing and took her for a spin.....Slow as a dog.......not sure whats up with that, but the belt has not slipped thus far.....also changed the dizzy......not sure how that would effect the belt slipping but im not going to complain...more ideas on y its slow would be appreciated, ECU is a chipped p30 runnin a VISION program.
Old Dec 12, 2004 | 09:11 AM
Civic92Turbo's Avatar
try a stock p30 and see the differents...you might wanna do a compresstion test/leakdown test...Maybe a SeaForm?
Old Dec 12, 2004 | 12:28 PM
did a compression test about a week ago, had 220 all cylinders...but my intake cam gear was advanced 10 degres (to get it to start) so my buddy said that would effect it...doing another test tonight on stock timing, will post results after. thanks for the reply.....will also try another ECU and see what happens.
Old Dec 12, 2004 | 06:13 PM
compression tested, 220 all cylinders once again......im stumped....we will see what happens when i put the new tensioner on.....i put a used one on it b4, just to see if that would work, maybe my spare was bad too.....this is so frustrating.......
Old Dec 12, 2004 | 06:20 PM
DAguyLS's Avatar
just keep wrenchin away, you'll get it
Old Dec 13, 2004 | 08:14 AM
I hope so....if i cant figure it out in the next few weeks, shes gonna be d-series......
Old Dec 13, 2004 | 09:26 AM
JDMstance99's Avatar
Thats what happens when you do a backyard swap
Old Dec 13, 2004 | 11:25 AM
Default Re: (JDMstance99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstance99 &raquo;</TD></TR><TR><TD CLASS="quote">Thats what happens when you do a backyard swap</TD></TR></TABLE>
First off, you waste my time, by saying something like this, if you have no technical advice then do not post. And secondly, my buddy and I have done dozens of b,d,h series swaps, so not exactly a backyard swap..........
Old Dec 13, 2004 | 01:13 PM
If you don't do it yourself, then I dont <U>WANT</U> to know how much you pay to have your swaps done. DIY is the best. It's going to break sometime, and then you also know how to fix it.
Old Dec 13, 2004 | 04:32 PM
t-powersi's Avatar
Default Re: (31flavorscivic)
well seeing that u were advanced so much with the cam gears yo chould maybe have some bent intake or exhaust valves that gives alot of power loss but the compression is ok so maybe not, or the tensioner puelly is is bad or the bolt is coming loose
Old Dec 13, 2004 | 04:59 PM
motor internally is strong as ****....so its gotta be something else....right now im prayin its the tensioner, which should be in tomarro, if not, i really dont no.......however, does anyone know what effect a bad water pump would do on a timing belt.....? i dont think mine is bad, but i just need ideas.....thanks again.
