Shifting into 2nd when cold out.
Old Dec 4, 2004 | 09:42 AM
kevin85193's Avatar
Default Shifting into 2nd when cold out.
I purchased a 98 GS-R about a month ago, and lately it's been getting really cold(btw this is my first manual car). I've noticed when I start the car up it's idling at around 1k-2krpms because it's cold out. Now, when I first take off, I'm in first, but when I switch to 2nd, it gives me a little trouble. It seems to pop back out. When the car is warm and the RPM's are normal, it works fine. Is this something to worry about or what? It like doesn't pop, pop out... but it kind of feels like it doesnt want to go into 2nd.
Old Dec 4, 2004 | 09:48 AM
GG-SquadDB's Avatar
Default Re: Shifting into 2nd when cold out. (kevin85193)
why not let the car get to regular temp instead of driving it cold its never good to drive the car when its not at operating temp....
Old Dec 4, 2004 | 10:12 AM
LS_DON4500's Avatar
true very true, let it get to operating temp! another tip essp. in cold weather, the shorter the distance your gonna drive the car like say to the local store, it isnt good on your car, the farther distance you drive will be better on your car, sounds stupid but very true, because your starting your car and turning it off so quick, so let it run, dont start it and go right away, warm her up
Old Dec 4, 2004 | 10:31 AM
Moogen Powah's Avatar
Default Re: (LS_DON4500)
Just warm your car up for about three mintues and you should be fine.
Old Dec 4, 2004 | 10:36 AM
FastSS's Avatar
Default Re: (Moogen Powah)
You cant wait for a car to warm up to temp, oil takes way longer than coolant, and waiting for the tranny fluid to soak up the heat from the engine would be ludacris
I agree on the 3 minutes, I usually let mine warm up 3-5 minutes or so when its really cold
My roommate has a block heater on his Integra, which is something I feel is a must for those REALLY cold mornings. Then again, I am a diesel guy and my truck is plugged in whenever its parked if its below 20
Old Dec 4, 2004 | 10:43 AM
Tweakmeister's Avatar
seems kind of like an issue...if you have the time and money, I would take these steps in troubleshooting it:
-Inspect tranny shifter linkage rod and bushings
-Inspect engine bushing mounts
-Change tranny fluid
Old Dec 4, 2004 | 12:02 PM
95lstegman's Avatar
Default Re: Shifting into 2nd when cold out. (Tweakmeister)
if the problem is in the tranny (as opposed to simply the tranny has not had a chance to circulate the gear oil, which is thicker than normal when cold so will not circulate as quickly), it is much more likely to be a bad synchro than shifter bushings or whatnot, especially considering it's second gear, which is probably #1 most often "banged" gear. okay, now give me an award for longest sentence ever!
Old Dec 4, 2004 | 12:43 PM
b18bme's Avatar
Default Re: Shifting into 2nd when cold out. (95lstegman)
I have the same problem with mine, so it isn't anything to do with the clutch??? it doesn't grind at all or anything it just has a hard time going into second, and third and reverse. I thought it was the clutch but maybe I'm wrong, it started happening all at the same time about 2 weeks ago (don't mean to hijack the thread).
Old Dec 4, 2004 | 04:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">if the problem is in the tranny (as opposed to simply the tranny has not had a chance to circulate the gear oil, which is thicker than normal when cold so will not circulate as quickly), it is much more likely to be a bad synchro than shifter bushings or whatnot, especially considering it's second gear, which is probably #1 most often "banged" gear. okay, now give me an award for longest sentence ever!</TD></TR></TABLE>
yeah it very well could be mechanical...if it's a newly bought car I try to go easy on suggesting tearing things apart
Old Dec 4, 2004 | 04:45 PM
BLaCk N MiLd's Avatar
I know exactly what your talking about and i have the same problems and i usually let me car defrost / warmup for 5-10 minutes
Old Dec 4, 2004 | 05:05 PM
kevin85193's Avatar
Default Re: Shifting into 2nd when cold out. (BLaCk N MiLd)
yeah, was in a rush so i didn't let it warm up. Cars fine now.. drove a ton today.
Old Dec 4, 2004 | 05:11 PM
mugenracer's Avatar
I had the exact same problem in my JDM Si-VTEC...what i used to do was just drive slowly in 1st for a while and it then usually went into 2nd without a problem. You could try changing the tranny oil for HMTF2 and see if it cures it....
Old Dec 4, 2004 | 06:24 PM
WhiteGSR95's Avatar
so it only happends on start up? then chances r that its cuz ure gear oil is cold, b8ut if it happends all the time, it could b a number of things,low gear oil, too much clutch freeplay, bad synchro shift linkage not adjusted
bopbop93030
Apr 15, 2008 07:14 PM
amej8
28
Feb 13, 2008 06:32 PM
Jmunk
Jun 4, 2004 02:19 PM
subtleluck
Oct 14, 2002 09:10 AM
M0NEYnH0s
Dec 27, 2001 09:41 AM
