Best place to get gaskets and best kind???
Old Jan 1, 2002 | 10:55 AM
B19CivicHB's Avatar
Default Best place to get gaskets and best kind???
I need a few gaskets and dont know the best place\kind to get. Any advice? I need the following gaskets: valve cover, intake mani, exhaust mani, head, oilpan.
Thanks in advance!
-Nick-
Old Jan 1, 2002 | 11:02 AM
Kamin's Avatar
Default Re: Best place to get gaskets and best kind??? (B18CivicHB)
Honda.
the exhaust manifold gasket is reusable if its in decent condition.
so are the others minus the intake manifold one...stupid paper gaskets.
[Modified by KAMiN, 8:03 PM 1/1/2002]
Old Jan 1, 2002 | 11:05 AM
lazyvietboi's Avatar
how bout that crazy hondata gasket?
http://hondata.com/heatshield.html
[Modified by lazyvietboi, 12:05 PM 1/1/2002]
B19CivicHB's Avatar
Default Re: Best place to get gaskets and best kind??? (KAMiN)
ugh.... dealer prices suck so bad....
Old Jan 1, 2002 | 11:09 AM
B19CivicHB's Avatar
Default Re: Best place to get gaskets and best kind??? (lazyvietboi)
hmm i wonder if that hondada shield is worth it... does that replace the stock gasket or is it in addition to it?
Old Jan 2, 2002 | 12:29 AM
B19CivicHB's Avatar
anyone else know of good places to get gaskets besides the dealer?? 300th post by the way!
Old Jan 2, 2002 | 01:02 AM
B18C-EJ1
Guest
Posts: n/a
http://www.hondaautomotiveparts.com
Old Jan 2, 2002 | 06:29 AM
hensley's Avatar
Default Re: Best place to get gaskets and best kind??? (B18C-EJ1)
Felpro makes good gaskets.
You should be able to buy them at any good "professional" parts store.
They are generally not available individually, except for the valve cover gasket. you will have to buy a kit.
Old Jan 2, 2002 | 08:54 AM
B19CivicHB's Avatar
i need the gaskets for a B18C, so i need an acura dealer
Old Jan 2, 2002 | 10:07 AM
da6_b17a's Avatar
New User
actually the majority of of b16a(honda) gaskets are the same as the b18c(acura).
Old Jan 2, 2002 | 12:01 PM
B19CivicHB's Avatar
Default Re: Best place to get gaskets and best kind??? (da6_b17a)
do you know exactly which ones are and which arent?
Old Jan 2, 2002 | 12:51 PM
dohcsideSi's Avatar
OEM !!!! http://www.hondrcarparts.com or call (888)53-Honda is my dealers public wholesale department we can get acura also (no accessories though) just mention honda-tech.
Old Jan 2, 2002 | 02:11 PM
B19CivicHB's Avatar
Default Re: Best place to get gaskets and best kind??? (dohcsideSi)
do you work there or something? could you get the gaskets for me? let me know. Thanks!
-Nick-
Old Jan 2, 2002 | 05:18 PM
Sam's Avatar
Sam
I have a Brand New Spoon head gasket if you want it, it's $80 for you.
Old Jan 2, 2002 | 07:23 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Best place to get gaskets and best kind??? (Sam)
The B16 head gasket is the same as the B18C
The GSR intake manifold gasket is the only one that is different.
All other VTEC gaskets (b-series) are the same.
Old Jan 2, 2002 | 08:21 PM
B19CivicHB's Avatar
so i want to get a gasket set for a 99-00 si then. Even the oilpan gasket and valve cover gasket are the same? Thanks!
Old Jan 2, 2002 | 10:33 PM
B19CivicHB's Avatar
what makes the Spoon gasket more special than a stock one?
Old Jan 2, 2002 | 10:46 PM
da6_b17a's Avatar
New User
the stock head gasket has three metal layers riveted together to make one gasket. on the other hand the spoon has only two layers, thus raising your compression ratio.
Old Jan 2, 2002 | 10:55 PM
976's Avatar
976
New User
http://www.hparts.com
Old Jan 3, 2002 | 10:12 AM
ahcjar103's Avatar
dont get that. get one for a 94 del sol vtec. i bet it's cheaper.
Old Jan 3, 2002 | 10:19 AM
Sam's Avatar
Sam
Default Re: Best place to get gaskets and best kind??? (ahcjar103)
All B16A & B18C head gasket is inter-changable for your info.
Spoon one rise the CR by 0.2.
Old Jan 3, 2002 | 10:53 AM
JDM nerbie's Avatar
New User
HONDA
don't get it for any aftmkt companies unless they work directly with honda
H22A4Me
Mar 4, 2006 06:26 AM
rasinhell
Jan 24, 2005 09:44 AM
inspyral
Oct 19, 2002 05:09 PM
