Can a catalytic converter be placed backwards ?
Old Dec 3, 2004 | 10:51 PM
RCautoworks's Avatar
Default Can a catalytic converter be placed backwards ?
Just wondering, I have a cat sitting here with no flanges or no labels in or out. Anyone know for sure ?
Old Dec 4, 2004 | 12:32 AM
Recluse03's Avatar
Default Re: Can a catalytic converter be placed backwards ? (90blackcrx)
ehhh i am pretty sur eit will only bolt up one way. if i remember corrctly the front most side has only 2 botls while the back side has 3. what company is it?
Old Dec 4, 2004 | 02:04 AM
Tyson's Avatar
i believe so. a cat will be either 2 or 3 stage and the gases need to go in the specific order to work properly.
Old Dec 4, 2004 | 09:34 AM
Default Re: Can a catalytic converter be placed backwards ? (Recluse03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Recluse03 &raquo;</TD></TR><TR><TD CLASS="quote">ehhh i am pretty sur eit will only bolt up one way. if i remember corrctly the front most side has only 2 botls while the back side has 3. what company is it?</TD></TR></TABLE>
Reading owns you, it has no flanges on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i believe so. a cat will be either 2 or 3 stage and the gases need to go in the specific order to work properly. </TD></TR></TABLE>
Yes now thinking about that, that is true. But how do I figure out which way this cat goes ? I forgot the real name of it, but what side is the little tube usually coming out on ? And which way is it suppose to point, I thought it was suppose to be on the driver side facing the engine.
Old Dec 4, 2004 | 10:36 AM
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">but what side is the little tube usually coming out on ? And which way is it suppose to point, I thought it was suppose to be on the driver side facing the engine.</TD></TR></TABLE>
From what I've seen you're correct. They point forward.....and on driver side. I'm wondering what those air tubes are really for....
Old Dec 4, 2004 | 10:43 AM
MR5sARECOOL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering, I have a cat sitting here with no flanges or no labels in or out. Anyone know for sure ?</TD></TR></TABLE>
Think next time before you reply.
I think it would go one way as well, but not 100% sure.
Anyone have pics to post?
Old Dec 4, 2004 | 12:49 PM
Default Re: Can a catalytic converter be placed backwards ? (MestizoRacer310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">
From what I've seen you're correct. They point forward.....and on driver side. I'm wondering what those air tubes are really for....</TD></TR></TABLE>
From what I understand an air pump can be hooked up to it so you can pump freash air into your exhaust. Does anyone else know what way it goes for sure ? Any pics would be great.
Old Dec 4, 2004 | 01:05 PM
UltimX's Avatar
darker side is from the engine to cat. Lighter side of the comb is where the gas leaves and exits out of the exhaust. Does that help?
Old Dec 4, 2004 | 01:07 PM
Default Re: Can a catalytic converter be placed backwards ? (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">darker side is from the engine to cat. Lighter side of the comb is where the gas leaves and exits out of the exhaust. Does that help?</TD></TR></TABLE>
No because last I looked the cat was pretty dirty on both sides, its been used before.
Old Dec 4, 2004 | 01:57 PM
mr. carpenter's Avatar
the tube is an air inlet tube as stated previously. not sure of actual placement but mine was installed withe the tube facing foward on the driver's side. i doubt it would matter since a cat is onlya metal composite screen that reacts with exhaust gasses to reduce the pollutants. i would just install it how the other post mentioned. tube forward on drivers side.
Old Dec 4, 2004 | 02:54 PM
drdisco69's Avatar
Default Re: Can a catalytic converter be placed backwards ? (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">tube forward on drivers side.</TD></TR></TABLE>
That is the air injection tube, and it's used for emissions, to attach an air pump to. Basically legal cheating on emissions by a manufacturer.
Old Dec 4, 2004 | 03:30 PM
Default Re: Can a catalytic converter be placed backwards ? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
That is the air injection tube, and it's used for emissions, to attach an air pump to. Basically legal cheating on emissions by a manufacturer. </TD></TR></TABLE>
lol yep , anyways I am gonna install it that way because thats the way I thought it went and everyone else is confirming it. Thanks
Old Dec 5, 2004 | 08:12 AM
Wes V's Avatar
I don't think that it makes any difference which way you mount it.
However, I was in much the same situation with the aftermarket one I bought and mounted it so that the air injection tube (capped off) points forward. The thought being that if it was going into a car that had an air pipe, it wouldn't make sense to have it pointing rearward (the hook-up pipe would have to be longer).
Wes
Old Dec 5, 2004 | 10:51 AM
drdisco69's Avatar
Default Re: Can a catalytic converter be placed backwards ? (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that it makes any difference which way you mount it.
I beg to differ:
http://auto.howstuffworks.com/...2.htm
Without the NOx being reduced to nitrogen and oxygen in the reduction, the oxidation stage won't have enough oxygen to react with the carbon monixide to for carbon dioxide.
Old Dec 5, 2004 | 12:06 PM
fourthgenhatchB17's Avatar
Without the NOx being reduced to nitrogen and oxygen in the reduction, the oxidation stage won't have enough oxygen to react with the carbon monixide to for carbon dioxide.</TD></TR></TABLE>
I just learned something about that in class. The 3 way cats have the NoX reducing stuff come first, rather than last like they used to. I wasnt really paying attention as u can tell...lol
EG5Boy
31
May 20, 2021 03:03 AM
beastman@
Oct 21, 2007 11:38 PM
colinproctor
Feb 4, 2005 07:59 PM
knowtomorrow3001
Jan 16, 2004 10:02 PM
Poey2
Aug 15, 2003 08:05 AM
