PLEASE HELP. Need my window rolled up.
Old Dec 3, 2004 | 08:36 PM
hitekper4mance's Avatar
Default PLEASE HELP. Now I need to know what wire to tap!!
Hi all. My car just came out of the body shop. I have no engine and most of the engine compartment has been dismantled. The problem I have is MY WINDOW IS DOWN. I need to roll em up but I have no power. How do I get my window up before it rains?!??!!? PLEASE HELP!!
Modified by hitekper4mance at 5:52 PM 12/4/2004
Old Dec 4, 2004 | 01:39 AM
burnout289's Avatar
Default Re: PLEASE HELP. Need my window rolled up. (hitekper4mance)
if you have all the wiring still in place, I would assume you could just hook up a battery for a minute. but I would think there is a manual crank somewhere like that little hole in the headliner so you can move the sunroof without power. if you are really in a pinch, you could take off the door panel and wire battery power right to the window switch. if you don't have a battery around, borrow someone else's car for a few minutes.
Old Dec 4, 2004 | 07:25 AM
Default Re: PLEASE HELP. Need my window rolled up. (burnout289)
Thanks. All the wiring is not on the car. I threw in a battery and connected the fuse box under the hood but that only powered the locks and my heater/ac. What wire would I tap to directly power the switch??
Old Dec 4, 2004 | 11:51 AM
burnout289's Avatar
ok, my haynes manual is for 90-93 and I don't know what you have, but here goes:
assuming 4 doors just in case, these are the wires that should be coming from a power source to the master switch:
left front: white/yellow
right front: blue/black
left rear: green/black
right rear: yellow/black
hope this helps!
1992honda
Jun 24, 2011 03:14 PM
lexruger
Sep 5, 2010 04:33 PM
4drint3gr4
Mar 16, 2009 02:21 PM
_Bug_
Nov 29, 2006 03:48 PM
UPYOURZ
Oct 20, 2005 04:42 PM
