Need some power windows help
I traded my car. When I did the guy told me that the right window switch needed too be replaced. He took the window off the track so you can still slider it up and down. I replaced the switch with a known good one and checked the fuses. The window isn't moving...the drivers side switch won't masked its work either and it works fine for the drivers side window.....kind of wondering what my next step should be.... Thanks guys
Re: Need some power windows help
I would test the power window motor by applying battery power to the motor. Unplug the motor plug and apply battery power (I normally use a separate 12 volt battery I have).
The power window regulator/motor unit probably may need to be replaced. Even if the motor works, the regulator maybe bad (e.g., broken cable, etc.).
