Honda reflash
Old Dec 3, 2004 | 12:04 PM
christoble's Avatar
Default Honda reflash
will the hondata reflash void the waranty. also which intake is better aem or injen. thanks
Old Dec 3, 2004 | 12:09 PM
redronin22's Avatar
Default Re: Honda reflash (christoble)
Search much?
The only thing that can go wrong with Hondata is :
You over rev and you blow your engine which no warranty would cover since you would be @ fault for the situation.
Injen AEM both are filters on a stick. Pick the one that you like best.
Old Dec 4, 2004 | 02:42 PM
typesfanatik's Avatar
hondata will void it in essence but only if the damge was caused by hondata. they cant find out you have hondata meaning they cant see it flashed on your ecu. but if you over rev to 10k and float a valve they can tell that its a great mod get it
Old Dec 5, 2004 | 10:02 AM
answer703's Avatar
go with the injen.ihave one on mine ,it really kicks.or if you have doubts go to clubrsx.com they have dyno tests on both the aem and the injen.(the injen puts out better horse)
Old Dec 5, 2004 | 08:53 PM
Crim82's Avatar
Default Re: (typesfanatik)
I thought the reflash still had a rev limiter?
Old Dec 6, 2004 | 07:36 AM
Kal's Avatar
Kal
Default Re: (Crim82)
it does
Old Dec 6, 2004 | 10:22 AM
krystar's Avatar
a rev limiter only prevents the engine from spinning itself too fast. it doesn't prevent you from misshifting at 80mph and dropping the transmission into 2nd gear, sending the engine into 11,000RPM's and bending a valve.
hondata voids as much of your engine warantee as can be. the ECU is the brains of your engine. you've just brainwashed it and told it to do something else. if anything happens to the actual engine, be prepared to pay out of pocket.
sloweredcivic
Oct 12, 2004 07:48 AM
sohcvtec66
36
Dec 8, 2003 09:30 PM
bottlefedb18c1
Jan 8, 2003 11:18 AM
B20LS-T
May 10, 2002 07:57 AM
Feb 22, 2002 07:24 AM
