Larger rear tire other than the stock size?
Would it be possible for me to put a slightly wider tire on the rear than what the stock size is? The size now is a 150/80-16. I was just wondering if it's even possible or not even reccomended.
depending on the wheel width and the swingarm clearance , yes it is possible to step up a little, but it will affect the quickness of handling in the turns a bit.
Kinda hard to explain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">
Kinda hard to explain</TD></TR></TABLE>
http://mc.bridgestone.co.jp/pdf/mcintroe.pdf
Keep it stock.
The previous owner of my gsxr had a 190 on it,
the thing's turn-in felt like a harley
I just roasted the **** outta that one and put a 180 back on it
night and day difference
the thing's turn-in felt like a harleyI just roasted the **** outta that one and put a 180 back on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Son »</TD></TR><TR><TD CLASS="quote">Bigger isnt always better. Why would you want a bigger tire?</TD></TR></TABLE>
He could be a straight line man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet »</TD></TR><TR><TD CLASS="quote">Would it be possible for me to put a slightly wider tire on the rear than what the stock size is? The size now is a 150/80-16. I was just wondering if it's even possible or not even reccomended. </TD></TR></TABLE>
Pointless, by puttign a wider tyre on the stock rim you will faltten the profile which will means you wont end up using all of the tyre and have much less feedback on turn-in.
it depends on your rim width and which tire you're going with. On my VFR, I'm going to go from a 150-160 rear but also going from a 120/60 front to a 120/70 front
