drum brake upgrads?
Old Dec 3, 2004 | 08:43 AM
HatchBox's Avatar
Skoobie no more...
Default drum brake upgrads?
Im just curious, is there any sort of aftermarket for DRUM brakes?
I know disks are better but im just curious. I dont have the time, money to convert to disk.
Thanks
Please save the "just save and upgrade to disk"
I know i know.
Old Dec 3, 2004 | 08:52 AM
EL Vap133's Avatar
Default Re: drum brake upgrads? (HatchBox)
Go rear disc brakes!
Old Dec 3, 2004 | 09:01 AM
davens's Avatar
84-87 CRX HF aluminum drums...bolts on, no mods
Porterfield makes a rear shoe in their R4-S compound
Stainless braided lines and you should be set
Old Dec 3, 2004 | 05:18 PM
jdm-crx's Avatar
if you wanna do a rear conversion go to fourthgenhatch.com
Old Dec 3, 2004 | 06:19 PM
HatchBox's Avatar
Skoobie no more...
Default Re: drum brake upgrads? (jdm-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Go rear disc brakes! </TD></TR></TABLE>
lol shuddup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-crx &raquo;</TD></TR><TR><TD CLASS="quote">if you wanna do a rear conversion go to fourthgenhatch.com</TD></TR></TABLE>
no, i dont care about rear disk swaps. . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">84-87 CRX HF aluminum drums...bolts on, no mods
Stainless braided lines and you should be set</TD></TR></TABLE>
what is the the difference between the 84-87 and the 90-91?
Arent drums supposed to be cast iron or a mix of aluminum/iron?
Also this company doenst make shoes for 90 drums ?
And they make braided lines for the rears? how much?
Old Dec 3, 2004 | 06:26 PM
Change's Avatar
the hf drums weigh 16 pounds less together then that ones you have.
Old Dec 3, 2004 | 06:35 PM
HatchBox's Avatar
Skoobie no more...
Default Re: drum brake upgrads? (pSI civic)
wow, thats quite a bit.
and there the same size as the 90-91 civic?
Old Dec 3, 2004 | 06:38 PM
Change's Avatar
thats what i've heard. i think that goes for the 88's as well. they should work with your car i think.
Old Dec 3, 2004 | 08:44 PM
RedRacerCivic's Avatar
I upgraded to 5th/6th gen civic rear drum brakes. They are bigger than 4th gen drum brakes. Here are pictures of the whole rear brake setup on my hatch.
Old Dec 3, 2004 | 08:59 PM
crxgator's Avatar
Default Re: (RedRacerCivic)
why?
why take the time and money to upgrade to a bigger drum instead of disc?
Old Dec 3, 2004 | 09:09 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (crxgator)
im not that Big on disk breaks im not a weekend auto crosser,
dont really care about the looks. just want some decent stoping power.
im not really looking to go to a bigger drum, just seeing if there is ANY aftermarket support for the drum brake
if i do the rear disk i have to buy the setup. ebrake lines, probally brake lines, would make sence to do the bushings in the trailing arms. it adds up, and for what a few extra stopping feet and less nose dive on braking.
Just exploring my options, I dont mind working on drums there not that bad. so why not see what the possiblitys are?
Old Dec 3, 2004 | 09:13 PM
crxgator's Avatar
Default Re: (HatchBox)
not you...
Old Dec 3, 2004 | 09:26 PM
HatchBox's Avatar
Skoobie no more...
haha ......wow
Old Dec 3, 2004 | 09:27 PM
bossman032's Avatar
upgrade the fronts to gsr/ls that will help better then getting the rear disk brakes.
The big brakes in front help out a lot you see the difference.
Light cars don't huge brakes.
Last time I was doing around 60-70mph in the rain I slammed the brakes not all the way just enough my rear started fish tailing. Front held up great no problems bigger is better
Old Dec 3, 2004 | 09:31 PM
crxgator's Avatar
Default Re: (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">upgrade the fronts to gsr/ls that will help better then getting the rear disk brakes.
Last time I was doing around 60-70mph in the rain I slammed the brakes not all the way just enough my rear started fish tailing. Front held up great no problems bigger is better </TD></TR></TABLE>
hmm...wow, that doesnt make any sense at all then and seems very dangerous to me...
Old Dec 3, 2004 | 09:38 PM
bossman032's Avatar
Dangerous is my middle name..
Ever hit a curb at 120mph and lived to tell about it..
I cracked the curb and swerved into a parking lot avoided flipping and hitting traffic on the other side. Thank god I am still alive.
Old Dec 3, 2004 | 09:51 PM
BOSS-REX's Avatar
You can drill holes in the corners of the drums in four spots around the outer hub corner.this will out-gas some of the heat and brake fumes.
Cheepest thing to help stoping power
Old Dec 3, 2004 | 09:59 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">why?
why take the time and money to upgrade to a bigger drum instead of disc?</TD></TR></TABLE>
Drums seem to actually be better the disc for auto crossing.
Old Dec 4, 2004 | 02:55 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1. what is the the difference between the 84-87 and the 90-91?
2. Arent drums supposed to be cast iron or a mix of aluminum/iron?
3. Also this company doenst make shoes for 90 drums ?
4. And they make braided lines for the rears? how much? </TD></TR></TABLE>
1. 84-87 light &gt; 88-91 heavy
2. Very good. Aluminum body, iron friction insert
3. uh, yes they do. Was that a question or a statement?
4. Look around. There are several manufacturers. What am I...your personal shopper?
Old Dec 4, 2004 | 06:45 AM
HatchBox's Avatar
Skoobie no more...
Default Re: drum brake upgrads? (davens)
you made it seem like they only made them for the 84-87 drum
i was only asking, chill.
HatchBox's Avatar
Skoobie no more...
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Drums seem to actually be better the disc for auto crossing.</TD></TR></TABLE>
do you know exactly why this is?
Old Dec 4, 2004 | 06:59 AM
crxgator's Avatar
take dave with a grain of salt...
they are better for auto-x cause they are lighter, but people with disc dont usually swap out disc for drums, they just dont upgrade to disc...personally i wouldnt upgrade my rear drums to another set of rear drums, that is what i was getting at last time...
i didnt mean actually upgrading like shoes and drums, i mean taking rear trailing arms off of another civic and putting them on like redcivicracer did...
Old Dec 4, 2004 | 07:11 AM
davens's Avatar
Let me tell you where you can stick your salt
Are drums better for autox? ....No. Wishful, compensatory thinking.
Are discs better then drums? ....Not performance wise. They are easier to service, stay adjusted better and look a damn sight better though.
Don't get anything for the 84-87 except the drums. Use your models pads, lines etc etc.
And the HF drums ain't cheap. Like $75 each the last time I checked Autozone.
Old Dec 4, 2004 | 08:22 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote"> Let me tell you where you can stick your salt
More surface area= better braking...
Right?
And arent the drums on the civic duo servo (self adjusting)?
Is there a core charge on them? My local parts store doesnt care. When i ordered my LS axles i gave them my stock d series axles heh
Old Dec 4, 2004 | 08:44 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">More surface area= better braking...
Right?
Is there a core charge on them? My local parts store doesnt care. When i ordered my LS axles i gave them my stock d series axles heh </TD></TR></TABLE>
I don't know about surface area comparison between the two setups but performance wise, we're talking marginal differences.
Supposed to be self adjusting but they sometimes need a fix...more then discs ever do.
Why don't you call your local parts store and tell us.
