CEL passed diagnostic test, why?
Old Dec 3, 2004 | 07:26 AM
Rabid's Avatar
Default CEL passed diagnostic test, why?
I've had this check engine light come on for the last two weeks every time I start the engine. It comes on a few seconds after start. I took it to two different autozones and both times the test reads the ecu and reports "passed" with no codes. What could this be?
Old Dec 3, 2004 | 08:17 PM
hatchi's Avatar
Default Re: CEL passed diagnostic test, why? (Rabid)
when the check engine light goes on pull over and jump it
Old Dec 3, 2004 | 10:44 PM
leed's Avatar
Default Re: CEL passed diagnostic test, why? (hatchi)
Does it ever come back on after fuel pump prime with key-on engine off? Or is it only after it starts? What ECU?
Old Dec 5, 2004 | 07:50 PM
Rabid's Avatar
It comes on during priming pulse and off at end prime pulse. But that's normal. It comes on about 3-5 seconds after engine start every time.
I don't know off hand what ecu it has but it's a 2000 civic with d16y7 engine and manual transmission. E5 or something.
I just got a haynes manual with codes and I jumped the service connect wires. I didn't get it to blink until I started the engine. I bet that's why they didn't get a code at autozone. It blinked out 65, secondary heated O2 sensor heater circuit fault. (Sensor 2) Well that makes sense. I have replaced the primary O2. I have turbo and no cat. I just put the secondary sensor 2' down the down pipe from the primary and haven't had a problem until now. Maybe I should make a simulator?
The moral of the story is, start the car to get codes that don't show up otherwise.
Old Dec 6, 2004 | 03:44 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rabid &raquo;</TD></TR><TR><TD CLASS="quote">It comes on during priming pulse and off at end prime pulse. But that's normal. It comes on about 3-5 seconds after engine start every time.
It is supposed to do this, its a self test....and its the way most small shops know that you don't just have your CEL bulb taken out
hondacivic97si
Jun 16, 2015 10:37 AM
demo024
Feb 17, 2011 03:17 AM
oilspot
Feb 24, 2009 10:16 AM
bugster
Mar 2, 2007 06:14 PM
blk_eg4
Dec 8, 2006 01:04 PM
