FS: EG and EF parts in Chicago...
4040 brake proportioning valve from Integra - $40
B Series stock crank pulley - $30
B16a1 Fuel Rail - $30
B16a1 rear engine bracket - $40
B16a1 Fuel Injectors (OBD0) - $40
B16a1 Distributor - $100
EG stock Fuel Pressure Regulator - $30
Stock CRX airbox w/practically new K&N filter - $30
Stock CRX radiator fan (shroud is partially cracked - $20
Stock CRX radiator (Very good condition) - $60
EG D series axles - Good condition - $50
EG engine mounts (a few can be used for B swap) - $80
EG Fuel Injectors (OBD1) - $40
Stock EG airbox - $30
Stock EG radiator - bent fins but still works good - $20
Greddy Oil Cap - $25
'94 Civic EX 15/16" stock "Nissin" Master Cylinder - $40
Momo black/yellow 11.5" steering wheel - $100
OEM '92-'95 Civic mud flaps - $50
Neuspeed Sport Springs(~1.5" drop) for '92-'95 Civic - Practically New - $110
Virgin P28 manual ecu - $120
P07 Civic VX ecu - $40
D16z6 SOHC Vtec distributor - New cap/rotor/igniter/coil - $100
Suspension Techiques Sway Bar Kit(F/R) for 88-91 Civic/CRX - $150
Neuspeed Front Strut Bar for 88-91 Civic/CRX - $50
Neuspeed Lower Rear Tie Bar for 88-91 Civic CRX - $40
Local Pickup only for items below:
Civic HX wheels w/ 185-65-14 Dunlop SP Sport A2 tires (~50% worn) - $200 (small dime size gouge on one wheel, ~1.5" surface scratch on another - but all work good)
Civic VX wheels w some crappy tires - $100
EG fiberglass hood painted black, drilled for hoodpins - $150
No Trades. Paypal accepted. Pics Upon Request. Many References Available. Shipping usually done next business day. No Flakers. Lowballers will be ignored.
sohcFerio
Oct 21, 2012 08:27 PM
eghatch9295
Mar 7, 2012 09:39 PM
