Type-R crankpully?
Old Dec 31, 2001 | 09:05 PM
WykidEH's Avatar
Default Type-R crankpully?
OK, I know that at some time you were able to get the R without power steering. What I'm looking for is the crankpully for one that only has the A/C and alt. pully grooves. Anyone know where I can one or if anyone knows what I'm talking about? Thanks
Old Dec 31, 2001 | 09:17 PM
sgT's Avatar
sgT
Default Re: Type-R crankpully? (WykidEG6)
The ITR ALWAYS had P/S. A/C was optional here and in japan.
Old Dec 31, 2001 | 10:57 PM
WykidEH's Avatar
Default Re: Type-R crankpully? (sgT)
Is there a B series engine that didn't come with P/S? i want to use a crank pully that doesn't have one, that won't throw out my balance on my crank assembly. I have a '95 GSR bottem end w/pistin/rods and a B16 head.
Old Jan 1, 2002 | 06:27 AM
BudMan's Avatar
am i missing something??? having the extra slot on the crank pulley shouldn't throw anything out of balance. Just run without the belt - no biggy. If you are concerned about the weight, then get Unorthodox underdrive pulleys (you can buy the crank seperately, but I like the entire kit myself.)
jmho
Old Jan 1, 2002 | 11:04 AM
sgT's Avatar
sgT
To my knowledge there was no b series engine that came w/o power steering.
My suggestion to you is to get an unorthodox street pulley and have the ps ring
machined off and rebalanced.
Old Jan 1, 2002 | 11:08 AM
Turbo00's Avatar
New User
i believe the CTR pully had only an alternator on it
Old Jan 1, 2002 | 11:13 AM
IntegraT's Avatar
Yes, if I'm not mistaken Honda uses it on the N1 Civic Type-R's. This crank pulley is pre-balanced from the factory and weighs a mere 1.8 pounds. It does not have any A/C or powersteering. Also, unlike most aftermarket crank pulleys, it has all timing marks...just like your factory pulley.
Old Jan 1, 2002 | 11:14 AM
ITR764's Avatar
Default Re: Type-R crankpully? (Turbo00)
that would be correct. R&D has them on order (back order for like the past year).
Old Jan 1, 2002 | 11:17 AM
Mike M's Avatar
Founding Member
The CTR N1 Pulley Has only the alternator Groove on it, No PS or AC
Old Jan 1, 2002 | 11:40 AM
sgT's Avatar
sgT
Default Re: Type-R crankpully? (IntegraT)
1.8lbs?!?
Geez thats WAY too heavy.
Unorthodox Race pulley = few ounces.
project civic
Jun 3, 2005 12:09 PM
SuicideSlide
Aug 11, 2004 03:43 PM
coolusername
Aug 28, 2003 10:47 AM
