will this amp be able to pound two 10" subs?
Old Dec 31, 2001 | 08:47 PM
William's Avatar
New User
Default will this amp be able to pound two 10" subs?
I'm gonna get a pyramid 800W 4 channel amp from a friend, and 2 JL 10" subs from another friend. I was just wondering if they'll make good bass? I'm paying just 60CDN for the amp so I'm a bit worried if it'll not be able to pound the subs. Deck is 45W btw, with stock speakers.
Old Dec 31, 2001 | 09:07 PM
joesosilly's Avatar
Default Re: will this amp be able to pound two 10" subs? (William)
wow, thats pretty cheap for that amp. as long as it'll pump out those watts you should be ok. you could also wire your amp bridged in series or parallel. just find out if your amp can hanldle the load. good luck.
Old Dec 31, 2001 | 09:39 PM
Mista Bone's Avatar
D Tranny Guru
I'll try to be nice, but likely your head unit has more juice than the Pyramid amp.
Old Jan 3, 2002 | 03:15 AM
William's Avatar
New User
Does that mean the amp is worthless?? sorry I don't know dang about audio stuff
Old Jan 3, 2002 | 12:27 PM
Mista Bone's Avatar
D Tranny Guru
Basically.........Yes.
Pyramid = Purajunk.
Whatever you do, do not push it hard so that it gets hot. Pyramids get hot easily and then the solder joints start failing.
Old Jan 4, 2002 | 05:25 AM
Daemione's Avatar
Default depends on the subs.
What model JL's are they? The recommended RMS rating is what you want to look at. If they're w0's, you might be alright - they can sound pretty good at like 100 watts a piece. I would hope the amp would do at least that much.
Old Jan 4, 2002 | 11:55 AM
MachAF's Avatar
That 800W pryamid amp will be lucky if it puts out 100watts.
Old Jan 8, 2002 | 12:27 AM
X2BOARD's Avatar
Default Re: will this amp be able to pound two 10" subs? (machaf)
The pyramid amp will pound those sub right into distortion heaven...
Old Jan 12, 2002 | 11:56 PM
turbocoupe's Avatar
Default Re: will this amp be able to pound two 10" subs? (X2BOARD)
I gotta Punch 200 4channel . . , I bridged down two kicker 10" comps and it sounded great! Ditched the speakers for new ones. . .the amp is sitting shotgun in my car. . .if your interested let me know.
Old Jan 13, 2002 | 06:17 PM
SoCal ITR's Avatar
Punch is good, I have a 250 powering two RF 10's
Old Jan 14, 2002 | 05:41 PM
JCushing's Avatar
well i would have to say that pyramid is a step up from rockwood or kenford but not that great at all. if there cheap and it sounds good to you then i say go for it though. however its hard to answer your question (kinda vague) i will tell you that the best way to see how much power an amp actually puts out is the fuse rating. all amps are based on a 12v system so with that being equal in all amps the only way to make more power is more current. amp makers lie about ther power output because watts = sales. however if they lie and put too big a fuse on there amp they will catch on fire and prolly kill people so its abou tthe only way withough Actually bench checking the amp to see the RELATIVE power COMPARED to another amp
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
Orpheus1985
Jul 21, 2005 07:15 AM
Mr. Choi
Apr 19, 2004 10:06 PM
cd5_2NR
Mar 18, 2004 06:17 PM
