Fuel Pressure Regulator Question!!!!!!!!!!!!
Old Dec 2, 2004 | 08:25 PM
xbn83's Avatar
Default Fuel Pressure Regulator Question!!!!!!!!!!!!
Hey guys, hope yall could tell me what is wrong with my fuel pressure regulator. I have AEM fuel rail with AEM fuel pressure regulator along with a lot of other bolt ons. I have a fuel pressure gauge hook up right on the fuel rail. I just notice that the fuel pressure never go down even if I leave my car not running for couple day. I always set my fuel pressure at 40psi and it never drops. It wasn't like that b4 when I first installed it. I have it for about 1 year. Is there anything wrong with that? Thanks!
Old Dec 2, 2004 | 09:08 PM
SuperSlow's Avatar
Default Re: Fuel Pressure Regulator Question!!!!!!!!!!!! (xbn83)
open gas cap, release the pressure from your fuel line while watching needle go down. When is the last time you changed your fuel filter?
Old Dec 2, 2004 | 09:11 PM
xbn83's Avatar
I bought the car used had 42000 mile on it. It is a 99 Prelude base. I didn't change it yet, and I don't think the last owner did it either.
Old Dec 2, 2004 | 09:20 PM
SuperSlow's Avatar
Default Re: (xbn83)
Part is cheap. and changing it is pretty simple, if annoying.. just make sure you have a flare wrench (line wrench or pipe wrench). Search if you need further info.
Old Dec 2, 2004 | 09:23 PM
xbn83's Avatar
Will changing the fuel filter will fix the problem tho?
Old Dec 2, 2004 | 09:28 PM
SuperSlow's Avatar
Default Re: (xbn83)
At 43k you should change it anyway. Sticking needle will happen often on the cheaper air/gas filled guages. I have not known the water filled to fail this way. Your car is running fine though right?
Old Dec 2, 2004 | 10:09 PM
xbn83's Avatar
My car runs fine. I have B&M fuel pressure gauge mounts right on top of the fuel rail. I 'm very sure the needle is not sticky at all. When I rev the engine by the throttle cable, it moves up and down.
Old Dec 3, 2004 | 07:12 AM
SuperSlow's Avatar
Default Re: (xbn83)
just move the adjuster screw on the fpr, and if the needle moves too, then you are fine. leave it alone.
Murk 'EM
Oct 6, 2007 08:04 PM
jman86
Aug 26, 2006 08:13 AM
Shmaa
Jul 7, 2006 04:59 PM
chefcris420
Jul 20, 2001 11:34 AM
