Do these look like 00 ITR cams to you?
Old Dec 2, 2004 | 06:05 PM
PIC Performance's Avatar
Default Do these look like 00 ITR cams to you?
Also, does that look like a LOT of wear on the cams as well?
Old Dec 2, 2004 | 06:10 PM
99 TYPE R's Avatar
we can only see 3 lobes on the cam so we cant tell the wear, also 00,01 itrcams have 2 rings on the distributor cam correct me if im wrong guys..
Old Dec 2, 2004 | 06:11 PM
FerioVtec94's Avatar
Default Re: Do these look like 00 ITR cams to you? (Noob4life)
those look like either 97 usdm itr cams or 96+jdm itr cams
Old Dec 2, 2004 | 06:23 PM
xtcat9k's Avatar
Default Re: Do these look like 00 ITR cams to you? (FerioVtec94)
Look like 96+ JDM ITR cams to me
Old Dec 2, 2004 | 08:47 PM
1993sir05's Avatar
def not 00 itr cams.
Old Dec 2, 2004 | 09:20 PM
wizards581's Avatar
Default Re: Do these look like 00 ITR cams to you? (1993sir05)
all itr cams are not same? they change every year?
Old Dec 2, 2004 | 09:34 PM
Slain's Avatar
00-01 have a little more duration on the intake cam nothing to lose sleep over
Old Dec 3, 2004 | 04:55 AM
JinDIESEL's Avatar
Default Re: Do these look like 00 ITR cams to you? (wizards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizards581 &raquo;</TD></TR><TR><TD CLASS="quote">all itr cams are not same? they change every year? </TD></TR></TABLE>
to my knowledge, the 96-97 versions are different from the 98 and 01 specs ... the 96-97 uses ITR cams and the 98-01 versions uses the CTR cams. it's more aggressive.
Old Dec 3, 2004 | 05:14 AM
CWTegRNo.160's Avatar
Default Re: Do these look like 00 ITR cams to you? (JinDIESEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">
to my knowledge, the 96-97 versions are different from the 98 and 01 specs ... the 96-97 uses ITR cams and the 98-01 versions uses the CTR cams. it's more aggressive.</TD></TR></TABLE>
I thought 97-98 cam were different from the 00-01 (CTR cams)
Old Dec 3, 2004 | 05:43 AM
ebelp's Avatar
Default Re: Do these look like 00 ITR cams to you? (CWTegRNo.160)
This is why I'll never buy a used set of cams. 1. They all look the same. 2. You can't tell how many miles are on them.
Old Dec 3, 2004 | 09:26 AM
RGoose18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWTegRNo.160 &raquo;</TD></TR><TR><TD CLASS="quote">I thought 97-98 cam were different from the 00-01 (CTR cams) </TD></TR></TABLE>
They are, that's why so many 97-98 owners switch out their intake cams for the CTR intake cam. Waste of money IMHO
Old Dec 3, 2004 | 11:35 AM
1993sir05's Avatar
yeah but the easiest way to tell the intake cam is to looks at the dizzy side of the intake cams and see if it has two rings around it, if so its at least a 00-01 itr cam or a jdm ctr intake cam. that what i do know.
Old Dec 3, 2004 | 02:14 PM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">
Also, does that look like a LOT of wear on the cams as well?</TD></TR></TABLE>
man thats scary, i have a set of B16 sir cams that look just like that.. I can not tell these things apart.
RippSpeed
May 12, 2007 09:17 PM
GSRintegra_Bob
Oct 10, 2005 09:49 AM
ENeRg3Tic
Feb 26, 2004 03:54 AM
IC x Prince
Feb 24, 2003 09:31 AM
crx88si
Jan 24, 2002 11:40 AM
