90 crx gauge cluster
Old Dec 2, 2004 | 05:55 PM
slipperyduck's Avatar
Default 90 crx gauge cluster
i just did a crx dash conversion into my 89 hatch std now i have a problem with the cluster off the crx not working right nothin works can neone help wit schematics or ne links thanks
Old Dec 2, 2004 | 08:29 PM
dr_latino999's Avatar
Default Re: 90 crx gauge cluster (slipperyduck)
The wiring is different between the 88-89 and the 90-91 chassis. If you want to save yourself a hassle of re-wiring, pickup a 88-89 CRX cluster.
Old Dec 2, 2004 | 08:30 PM
mr. carpenter's Avatar
there is a link in the faq to 4thgencivic and i believe there is a wiring diagram there.
Modified by mr. carpenter at 8:32 PM 12/4/2004
Old Dec 3, 2004 | 07:59 PM
Default Re: 90 crx gauge cluster (mr. carpenter)
faq where
Old Dec 3, 2004 | 08:23 PM
bump
Old Dec 3, 2004 | 09:12 PM
faq at the top of this forum. also serached and found this.
http://www.4thgenerationcivic.com/
Old Dec 4, 2004 | 02:15 PM
i went there and there is only has the integra cluster not the 88-89 to 90-91 conversion neone have ne other links
Old Dec 4, 2004 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipperyduck &raquo;</TD></TR><TR><TD CLASS="quote">i went there and there is only has the integra cluster not the 88-89 to 90-91 conversion neone have ne other links</TD></TR></TABLE>
read it a little better, it's there. right behind where it says integra cluster.
Old Dec 4, 2004 | 02:24 PM
****, i'm sorry. you're right. it says it's there but it's been taken out. it was there at one time because that's where i did mine. i'll look around some more. i found this thread. you could im this guy and get a little better info from him. also search archived crx ef forum for "si cluster swap". i got alot of results.
Old Dec 4, 2004 | 02:40 PM
thanks for the help i really didn't know how to search it
Old Dec 4, 2004 | 10:33 PM
here's the thread. i forgot to attach it earlier.
https://honda-tech.com/zerothread?id=858345
Old Dec 5, 2004 | 11:41 AM
ok i goit everything workin but when i turn on the car the temp gauge just jumps all the way up any ideas on whta is making this happen thanks
Old Dec 6, 2004 | 03:07 PM
bump
Old Dec 6, 2004 | 03:12 PM
Rywire's Avatar
fyi, 88 and 89 clusters differ in wiring, I dont know how much but they do. the seatbelt is in 2 diff spots, so thats one change right there.
Ryan
crxrider
Aug 21, 2007 02:59 PM
arsonest42
Apr 30, 2007 06:34 AM
AndrePerras
Dec 3, 2006 06:16 PM
Jay.D.Em!
Feb 7, 2006 03:06 PM
Vaans
Aug 2, 2004 01:24 PM
