I think my slave cylinder is thrashed
Old Dec 2, 2004 | 05:52 PM
01itr#664's Avatar
Default I think my slave cylinder is thrashed
how much is one? what do you do on the install besides bolt it on and hook the line up.. any advise would be nice!! thanks..
"There once was a man from nantucket..."
Old Dec 2, 2004 | 06:00 PM
AlxSiR7's Avatar
Default Re: I think my slave cylinder is thrashed (01itr#664)
$15-$20 i think.. if it's anymore than that just go to acura and say you work for a dealer & want this dealer courtesy discount. then it just bolts in.. but you gotta bleed the line. its really simple.. just have a friend pour brake fluid in the master cylinder while you pump the clutch (have a hose hooked up to the bleed valve).. wait no, just turn the fluid bottle upside down into the master cylinder reservoir and 1 person pump the clutch and someone else tighten the drain bolt on the slave cylinder when you stop seeing bubbles..
NhoedeEJ1
Transmission & Drivetrain
13
Feb 27, 2012 09:05 PM
.water
Apr 3, 2006 07:56 AM
ferio 95
Jul 22, 2005 10:03 PM
InspiredRacer
May 19, 2003 09:39 AM
AndyD
Mar 5, 2003 08:32 PM
