Side Moulding
I have black side moulding on my silver integra, Is the side moulding screwed on there or glued on i am thinking of repainting it myself. any special instructions on how to prep/paint them, if they are glued on what glue should i use to put them back, thanks in advance
I know they're not glued on. I'm pretty sure they are just held in by clips. I would suggest sanding them down, putting primer on, sanding that, then painting.
Remove your door panels and look behind the plastic liner, you will see the clips that hold them in place. You can use pliers to squeeze them together and pop them out. BE CAREFUL. These things have been known to brake easily.
Former User
12
Jun 10, 2012 12:53 PM
