Instruction to remove and install radiator?
heres an article from team-integra
http://www.team-integra.net/se...D=763
instructions? bah! just drain, unbolt, remove, replace, bolt, fill. have a friend handy to hold the AC lines out of the way if you have AC.
one thing to look out for: I had to replace one of the fan bolts because what I was given wasn't long enough. I can't remember exactly why, but make sure you have a ride to Home Depot just in case.
When I replaced mine, I unbolted the fans from the old radiator before pulling the radiator out. Then I bolted the fans onto the new one BEFORE putting the radiator in. I got a CSF radiator, and the fans and everything bolted up perfectly using the stock bolts.
dsadas89das78934
28
Mar 10, 2004 03:39 PM
