99 prelude abs indicator
Old Dec 2, 2004 | 05:42 AM
meohmy01's Avatar
Default 99 prelude abs indicator
My abs indicator light has just recently started coming on. the car has just under 49000 miles on it. A couple days ago it was in the shop due to the timing belt tensioner failing and needing the tenioner and timing belts replaced. when it was in the shop they put it up on the lift and showed me that the radials were exposed on the oem potenzas so after dropping 600 at the dealership for repairs i drove accross the street to drop another 600 on some new pirelli's. The day after i got the car back i checked my brake fluid and my clutch fluid and my oil, then afterwards the front end started to make what seems like a rattling noise when slowing down or reversing and then the abs light comes on. it doesn't come on all of the time and you can drive for miles and then have it come on. what are the possible problems i might be looking at. unfortunatley I can't afford to leave it to the professionals because i am all out of money. What are the different things that will set the light off. What should I look for? I'm fairly mechanically compitent so all I need is some guidence since I'm not all that knowlegable in the field of ABS.
Old Dec 2, 2004 | 06:04 AM
v4lu3s's Avatar
RTFM
id check teh ABS codes so you know what the problem is. you jsut count flashes like the engine light after putting the wire jumper in the check engine plug.
Old Dec 2, 2004 | 06:13 AM
meohmy01's Avatar
Default Re: (v4lu3s)
i'm not familiar with how to do this on this car. can anyone explain?
Old Dec 2, 2004 | 06:28 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (meohmy01)
So did the ABS light come on before the tire change or after?
Old Dec 2, 2004 | 06:31 AM
* B A N N E D *
Default Re: (STicky Tires)
Click here to read about pulling the codes.
Old Dec 2, 2004 | 08:55 AM
meohmy01's Avatar
after the tire change.
Modified by meohmy01 at 10:07 AM 12/2/2004
Old Dec 2, 2004 | 09:26 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meohmy01 &raquo;</TD></TR><TR><TD CLASS="quote">after the tire change.
Sounds like whoever installed the tires for you messed up your ABS/wheel speed sensors.
Bring it back to them and tell them about it. They'll probably deny it but do your best to get them to pay/fix it.
Or you can take your front wheels off, and check yourself. Research on where the sensors are. Or ask someone with a helms manual to give you a picture.
Old Dec 2, 2004 | 03:30 PM
meohmy01's Avatar
it wasn't the people that did the tires. there's a wire that goes to the abs that didn't get clipped back in by the honda dealership that did the timing belt tensioner so it was rubbing on a pully and eventually rubbed through and shorted out. problem fixed.
Old Dec 2, 2004 | 04:43 PM
v4lu3s's Avatar
RTFM
good deal those sensors are expensive i hope htey paid for it.
mfrs
Sep 5, 2015 12:32 PM
spacyfoil
Feb 26, 2010 07:38 PM
social_control
May 23, 2003 06:27 AM
