crx suspension advice wanted
Old Dec 1, 2004 | 09:59 PM
EFnerd's Avatar
Default crx suspension advice wanted
hey guys please stay from flames if u feel reason too. I do not know much about the suspensions of crx's or any car for that matter. now i am lookig to buy some sort of suspension parts to improve handeling, traction, controll, stability, ect you get the pic. what kind fo stuff should i buy and how much are certian things gonna cost? right now i have sticl suspension with neuspeed springs....thanks any advice would be appreciated.
-Adam
Old Dec 1, 2004 | 10:20 PM
mrspeaker's Avatar
Default Re: crx suspension advice wanted (crxnerd)
Get some adjustable shocks and keep the Neuspeed springs you have now..
KYB AGX or Tokico illuminas can be had for under $300 off ebay..
polyuerathane bushing kit..Around 100-130
dont waste your money with strut bars..They do nothing for the 88-91 chassis except look good and get in the way.88-91 chassis is already stiff..
Only a roll cage will actually stiffen up the chassis more then it already is..
But if you wanna be hardcore then you can get some re-vavled koni yellows with coilovers and custom rate springs...
But before u decide on a set-up..is this a drag racer,,auto-x,,street car/strip car..or just a daily driver ??
Modified by Mrspeaker at 12:47 PM 12/2/2004
Old Dec 1, 2004 | 10:30 PM
EFnerd's Avatar
Default Re: crx suspension advice wanted (Mrspeaker)
man thanks for prompt response...daily driver
Old Dec 2, 2004 | 05:57 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnerd &raquo;</TD></TR><TR><TD CLASS="quote">man thanks for prompt response...daily driver </TD></TR></TABLE>
Well if its a daily driver then kyb-agx or tokico illuminas would be good for you
They're both adjustable to give you a nice firm ride or a smooth ride for the highway..Lots of people have them set in the middle..
Tokico has a better warranty then kyb.....
and you should stick with the nuespeed springs you have now..or if you want different springs I recomend Eibach sportline or Pro-kit...Eibach springs never sag
Old Dec 2, 2004 | 06:27 AM
crxgator's Avatar
first thing i would do is check your rear trailing arm bushing, and replaced them if needed...
keep the springs like mentioned and pick up some AGX's, i have em with Sportlines and they are good for daily driver, light auto-x, make sure all your bushings are good as well...
then get some good tires(daily driver i use yokohama avs es100) and light-mid weight 15's...
you should be set for daily driver and some auto-x duty...
Old Dec 2, 2004 | 06:29 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: crx suspension advice wanted (crxgator)
revalved shortend koni's with custom spring rate G/C is prefectly fine for daily driving... as long as you arent above the 450-500 range in spring rates.
jrap1243
18
Jan 30, 2008 04:34 PM
bacnoonoi
10
Jun 18, 2007 03:47 PM
ej_randy
Mar 27, 2007 06:55 PM
JDM00SI
Jul 28, 2004 09:31 PM
