Ls/vtec buildup parts list
Old Dec 1, 2004 | 08:34 PM
Touge Tuning's Avatar
Default Ls/vtec buildup parts list
I just got an eg hatch with a 99 B18B1 and i wanted to go ls/vtec with it. So im wondering what are the essentials when doing this conversion and approx. cost of the parts.
I wanted to use a GSR head but they can be $$$ and hard to find up here in canada so im thinking 2nd gen B16? So far i have a short list and im looking for input on parts to add etc.
-B16 or GSR head
- GE Vtec conversion kit
-P28 ECU?
-New head gasket
I am not sure what else is required so if you could give me some info it would be appreciated.
Old Dec 1, 2004 | 09:56 PM
alphanumeric's Avatar
Default Re: Ls/vtec buildup parts list (scarlemthug)
long way to go...theres a lot of stuff you need...pmed too
Old Dec 1, 2004 | 10:13 PM
mtber's Avatar
read up on importreview.com they have a general article, also hondaswap.com
Old Dec 2, 2004 | 05:32 AM
Phatch99's Avatar
check out http://www.c-speedracing.com
Old Dec 2, 2004 | 12:12 PM
Thanks for the advice guys
Old Dec 2, 2004 | 12:39 PM
KoRE's Avatar
the head gasket comes with the GE conversion kit.
other than that i think you have listed all the parts. just have to wire in vtec if it isn't already
Old Dec 2, 2004 | 12:44 PM
From what im gathering the list would look like this
-B16 or GSR head
-P28 ECU?
-New head gasket
-vtec oil pump, water pump
-ARP Head studs would be a good investment
Anyone list other stuff for me?
Old Dec 2, 2004 | 12:50 PM
VtecDA9's Avatar
Default Re: (scarlemthug)
vtec oil/water pump = gsr timing belt. after the parts, then the machining and assembly is just as important.
Old Dec 2, 2004 | 01:00 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Not to be rude, but search for lsvtec. Honestly, it's how I got all my info for my build. Would definitely check that out...there are SO many threads on this it's unreal. I assure you you will learn more than you know right now. I know my response doesn't answer your question but it will help get our answers.
-Chris
Old Dec 2, 2004 | 01:32 PM
I have searched a bunch for ls/vtec and havent come up with alot of info as far as all the parts needed.
I thought with the GE kit you dont need to machine the block or are you just saying it would be a good idea?
What I am looking to do is build a mild street motor and then next year im gonna be putting together a turbo setup. I was thinking with a basis ls/vtec i would get more hp out of the engine and i would be happy until i got the whole turbo setup together.
What does a basic LS/vtec(b16 head) usually put down as far as whp/tq?
Old Dec 2, 2004 | 02:09 PM
KoRE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarlemthug &raquo;</TD></TR><TR><TD CLASS="quote">I have searched a bunch for ls/vtec and havent come up with alot of info as far as all the parts needed.
with the ge kit you don't have to machine anythign but you do have to tap your head for the plug but other than that it's simple
PrincessEva
Sep 23, 2007 10:34 PM
Wuman
Sep 7, 2007 07:29 AM
authentic plusONErandy
Jan 11, 2006 08:52 PM
god.loves.ugly
Aug 7, 2005 02:32 PM
