Where does the radiator hose go?
Old Dec 1, 2004 | 06:25 PM
B18Redline's Avatar
Default Where does the radiator hose go?
The radiator hose which connects from the radiator to the block. What is the path of the antifreeze? Reason I ask is I put some radiator leak tablets in the hose to dissolve and cement the radiator cracks but then wondered if it could damage my motor.
Old Dec 1, 2004 | 07:30 PM
Master23's Avatar
Default Re: Where does the radiator hose go? (Redline07)
Those aluminum fillers that you put in your radiator actually clogs up your heater core. Your better off just getting a new or used radiator. Its better than having your motor overheat and blow a head gasket or worse your motor.
Old Dec 2, 2004 | 06:57 AM
B18Redline's Avatar
my motor did overheat temporarily as the gauge needle went up to about 65% of the way up b4 I shut off.
do you think i'm fine?
Old Dec 2, 2004 | 08:26 AM
vtecb20coupe's Avatar
B A N N E D
i would say that you got lucky, yes. good thing that you caught it when you did.
Old Dec 2, 2004 | 08:45 AM
mattssi's Avatar
oh boy.
dwn2earth922
Sep 12, 2009 10:00 AM
vxtirent08
Mar 20, 2008 10:36 AM
VSBB6
Nov 5, 2005 01:51 PM
B18Redline
Dec 2, 2004 09:35 AM
kingpen
Oct 31, 2002 12:19 PM
