skunk2 im and idle? turbo!
Old Dec 1, 2004 | 06:17 PM
ludegetsmwet's Avatar
Default skunk2 im and idle? turbo! Help!
yes i know this has been covered somwhere and i tried searching but came up with nothing. I am now worried about my idle. it will rev up to 1k to 2k and then when i give it gas it will idle normal. it only does it at a stop. when i get on it it feels fine. I also heard that the loud sucking sound out of the air filter has something to do with it too. did i hook up the vacuum lines wrong or not getting a good seal or what. and did anyone get past the egr check eng light or no. does anyone know of a way to get past it. when i rebuild the motor and drop a turbo i would like to do hondata or uberdata. when i get a fuel management system and getting either a chipped p28 or p72. when i first installed the manifold i tried dropping a p72 or gsr ecu in to get rid of cel on egr but the car wouldn't start. Isn't there a p72 obd1 and obd2 ecu. Did i just use the obd1 ecu and that's why it didn't start. I'm in a little bit of a dilemma and want to sort these problems out but don't know what to do. I need to get the idle right for tuning and the new motor build and sure would like to get rid of the cel. Please help
Modified by ludegetsmwet at 11:35 AM 12/2/2004
Old Dec 2, 2004 | 10:26 AM
Default Re: skunk2 im and idle? turbo! (ludegetsmwet)
anyone!
Old Dec 2, 2004 | 10:54 AM
CFLude97's Avatar
i cant follow ur poblem.(that may be why you have no replys)..mabey you should try and clear it up better.
Old Dec 2, 2004 | 11:03 AM
98TypeSH's Avatar
Default Re: skunk2 im and idle? turbo! (CFLude97)
You wont be able to get rid of the check engine light unless you leave the EGR hanging there but still plugged into the wiring harness, OR if you switch to OBD1 with hondata, this way you can completly disable the EGR with the hondata program.
This EGR CEL could very well be the reason for your bouncy idle issue.
Old Dec 2, 2004 | 01:32 PM
Fly1865's Avatar
Default Re: skunk2 im and idle? turbo! (98TypeSH)
Maybe the lines to the IACV are backwards. Switch them and see if it fixes it.
scott_turner
Engine Management and Tuning
Aug 26, 2011 12:51 PM
ev0luti0n
Sep 27, 2005 07:42 AM
AMG
Sep 30, 2003 12:14 PM
AMG
Sep 30, 2003 08:50 AM
Nextelbuddy
Apr 29, 2003 09:37 PM
