oil leak help!
Old Dec 1, 2004 | 06:13 PM
magic hat #9's Avatar
Default oil leak help!
ok, this is regarding the metal cylinder protruding from the block that the oil filter is screwed onto......and, yes, the oil filter is put on correctly.
is there a gasket or other way for oil to leak from around the connection between the cylinder and the block? how is that cylinder attached to the block? can the cylinder get warped from over-tightened filters and not make a good seal with the filter?
i'm continuously leaking oil only when the car is running. i've replaced the oil pan gasket and the pcv oil/air breather box + o-ring. the oil doesn't appear to be coming from the valve cover gasket or headgasket (both replaced 8k miles ago). the oil is getting onto the exhaust manifold because i can smell hot/burnt oil.
the only evidence of leaking i see around the bottom of the filter and metal cylinder. i don't see any sources above this location.
any thoughts?
Old Dec 1, 2004 | 06:15 PM
Kenso's Avatar
HT White Ops
Default Re: oil leak help! (magic hat #9)
The metal cylinder is an oil cooler. There is a rubber o-ring that forms a seal between the cooler and engine block. Sounds like this o-ring is leaking to me.
Old Dec 1, 2004 | 06:18 PM
Default Re: oil leak help! (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">The metal cylinder is an oil cooler. There is a rubber o-ring that forms a seal between the cooler and engine block. Sounds like this o-ring is leaking to me.</TD></TR></TABLE>
is this oil cooler easy to remove once the filter is off? i guess there must be some place to fit a socket wrench on it, eh?
Old Dec 1, 2004 | 06:36 PM
cheezthis's Avatar
I just removed the one from my old block the other day. You'll need a 32mm socket to remove it. The middle part comes out in one piece, leaving the cooler itself. This will then pop right off. The seal is around $7-8 I think.
Old Dec 1, 2004 | 06:41 PM
Kenso's Avatar
HT White Ops
The threaded stud that the oil filter screws onto also holds the cooler in place. There is a nut built onto the base of the stud. It just unscrews from the block and then you can remove the cooler.
Old Dec 1, 2004 | 06:59 PM
so the cooler itself is really just a hollow metal cylinder? and slides right out of the block? i'm guessing this seal is a large diameter o-ring?
great news! sounds like an 'easy' job (famous last words) that doesn't require the removal of the exhaust manifold.
Old Dec 1, 2004 | 07:03 PM
Dan GSR's Avatar
it is easy, you should be able to do it in less than an hour
Old Dec 1, 2004 | 07:04 PM
Kenso's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">so the cooler itself is really just a hollow metal cylinder? and slides right out of the block? i'm guessing this seal is a large diameter o-ring?
great news! sounds like an 'easy' job (famous last words) that doesn't require the removal of the exhaust manifold.</TD></TR></TABLE>
Yeah, it's not hard. The o-ring fits in a groove on the back of the oil cooler. Remove the filter, remove the stud, pull the cooler away from the block, R&R the o-ring.
Old Dec 2, 2004 | 04:51 AM
daddy ITR's Avatar
Yeah, it's not hard. The o-ring fits in a groove on the back of the oil cooler. Remove the filter, remove the stud, pull the cooler away from the block, R&R the o-ring.</TD></TR></TABLE>
yep it looks like it only cost a couple of bucks for the o-ring, see site below
http://www.acuraautomotivepart...y.jsp
Old Dec 2, 2004 | 04:55 AM
Bbasso's Avatar
I know this is a wild suggestion, but did you check to see if the oil filter has one or two gaskets on it?
what I mean is sometimes the old Oring from an oil filter gets stuck on the block surface and then the new filter had a O ring... and then it does not seal properly.
Old Dec 2, 2004 | 05:19 AM
Default Re: oil leak help! (daddy ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy ITR &raquo;</TD></TR><TR><TD CLASS="quote">
linky no worky.
rob, no leftover filter seals - i always check.
one last question, i'll have to go buy a 32mm socket so will a regular shallow socket work or do i need a deep socket?
Old Dec 2, 2004 | 11:32 PM
cheezthis's Avatar
Pretty deep. The socket I used just fit, and it's 1" deep....just fit. It's the craftsman one. There are also axle sockets that are deeper.
Old Dec 4, 2004 | 11:50 AM
Default Re: oil leak help! (cheezthis)
what is the proper torque setting on this nut?
Old Dec 4, 2004 | 01:22 PM
cheezthis's Avatar
54 lb/ft
Old Dec 12, 2004 | 02:29 PM
got the job done! the new o-ring is a bitch to get in the oil cooler's groove and sandwiched between it and the block before the o-ring falls out also, i found the 32mm socket seemed 1mm too big. it worked but i would like to try a 31mm to see if it fit better (i had to borrow the 32mm as it was).
the old o-ring definitely seemed to be the culprit; it had dirt caked onto it.
Old Dec 12, 2004 | 02:47 PM
1GreyTeg's Avatar
Very good to know for the future.
Glad it worked out for you.
Old Dec 12, 2004 | 06:33 PM
1Quikgsr's Avatar
good job man yeah thats it the o-ring its a bitch to get to and out but glad you got it done..
Old Dec 12, 2004 | 07:14 PM
totsie7944's Avatar
Default Re: oil leak help! (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">it is easy, you should be able to do it in less than an hour </TD></TR></TABLE>
JustCant5topMe
Aug 16, 2013 12:18 PM
mrspeedy69
14
Feb 5, 2012 11:48 AM
patrick4588
Dec 12, 2007 09:37 AM
Acco12dv6
Oct 2, 2006 10:14 AM
92ehatch
Feb 21, 2006 07:02 PM
