motor doging at higher rpm!!!!
Old Dec 1, 2004 | 05:33 PM
ALL IMPORT's Avatar
Default motor doging at higher rpm!!!! YO I NEED SOME HELP , WHAT THE DILLY YO
i did a conversion & put a 2000 man gsr motor in my 96 ls auto right, my 96 comp runs the motor fine ( but obviously the v-tec aint popin yet)but i just traded a headlight for a 99 gsr comp & it plugs in perfectly it idles good but when u go its a Little weak, then it goes, then when u get up in the higher rpm the car jerks a little then dog's all out like its stalling hmmmm, got any ideas?
Modified by ALL IMPORT at 7:43 PM 12/1/2004
Old Dec 1, 2004 | 07:44 PM
m0nk's Avatar
Default Re: motor doging at higher rpm!!!! YO I NEED SOME HELP , WHAT THE DILLY YO (ALL IMPORT)
first and foremost i think the correct term is "bogging," don't get me wrong--i'm not a flamer, just a really **** retentive...
anyway, my first guess would be to get a tune-up, i find that everytime my car's sluggish i just swap a basica tune-up item (ie spark plugs/fuel filter/etc) and it gets back to full potential, but i dunno...
hope this helps, although i doubt it
-alek
Old Dec 1, 2004 | 08:10 PM
Oleg's Avatar
Did you change the fuel pump and/or fuel pressure regulator? Cause LS runs like 15psi lower presure than GSR, on WOT you will get hesitation cause there is not enoth fuel ....
Old Dec 2, 2004 | 03:19 AM
ALL IMPORT's Avatar
Default Re: motor doging at higher rpm!!!! YO I NEED SOME HELP , WHAT THE DILLY YO (Oleg)
everything that was attached to the motor was swaped, changed the fuel filter,
didnt chang out the fuel pump, but my ls comp ran the motor great had lots of power, the comp is upgraded but i dont think that would matter. i dont see why the 99 would make it act like this, unless i have to change some wires around that aint in the right spot
Old Dec 4, 2004 | 05:11 PM
Oleg's Avatar
you can only gues at that point......If i were you I would check the fuel pressure with the fuel pressure gauge, and then go from there. At least this way you would know that your pump works properly(get the specs for fuel pressure foe this engine)
Old Dec 4, 2004 | 08:34 PM
ALL IMPORT's Avatar
well it looks like we were all wrong, i was hopeing this would be the problem. i didnt have the v-tec hooke up yet so it was bogging the motor as soon as i ran the wires "watch out" runs like a champ. its my first v-tech motor & im impressed. it feels like a little shot of nos almost. thanks for your opinions though
eh2_y8
Jul 23, 2014 08:33 AM
novtek95
Jun 10, 2012 08:20 AM
DOHC Kid
Oct 29, 2008 01:55 PM
civicracer1993
15
Mar 20, 2003 08:29 PM
