will the front springs from an eg fit an 89 crx?
Old Dec 1, 2004 | 04:51 PM
Kyles ej1's Avatar
Default will the front springs from an eg fit an 89 crx?
just a simple yes or no. with out any modification. thanks
Old Dec 1, 2004 | 05:00 PM
EL Vap133's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (egcoupe)
Yes.
Old Dec 1, 2004 | 08:30 PM
mrspeaker's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe &raquo;</TD></TR><TR><TD CLASS="quote">just a simple yes or no. with out any modification. thanks</TD></TR></TABLE>
Yes..
But they have higher spring rates and will make the car sit alittle bit higher then stock unless you have or plan on swapping in a heavier motor..
I know u said to anwswer with yes or no but just tryin to help out..
All 88-00 civic springs and 90-01 integra springs fit ..
Old Dec 1, 2004 | 09:32 PM
Kyles ej1's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (Mrspeaker)
im trying to sell them and a guy w/ a crx needs some. appreciate your help to
Old Dec 1, 2004 | 10:05 PM
slate13530's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
All 88-00 civic springs and 90-01 integra springs fit ..</TD></TR></TABLE>
Does this include the rear springs too?
Old Dec 14, 2004 | 09:15 AM
Kyles ej1's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (slate13530)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slate13530 &raquo;</TD></TR><TR><TD CLASS="quote">Does this include the rear springs too?</TD></TR></TABLE>
does it?
Old Dec 14, 2004 | 03:58 PM
smart monkey's Avatar
I don't think they will fit cause the eg springs are longer than the ef springs. I bet you will have a hell of a time compressing them to fit onto the ef shocks
Old Dec 14, 2004 | 04:31 PM
Drives EG's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (smart monkey)
yeah, i thought you would have to swap the entire suspension set up since they're made for different lengths/weights?
Old Dec 14, 2004 | 04:32 PM
essex's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (hatch90)
they are taller...don't do it.
Old Dec 14, 2004 | 04:35 PM
Kyles ej1's Avatar
Default Re: will the front springs from an eg fit an 89 crx? (essex)
but will they go on w/ out modding, just the springs, im selling them and this dude really needs some.
Old Dec 15, 2004 | 04:40 PM
EF9_R_Killa's Avatar
everything fits, spring rates are different so heights will varry on drop springs...anything stock and your ef will look like a rally car if you run integ springs...shocks will fit too although the DA's are .25" taller, and if you use EG fronts then you must use the fork as well.
hondaboy1990
Jul 16, 2008 01:44 PM
55superbeetle
Aug 4, 2007 03:44 PM
twowords
Jul 1, 2007 02:03 PM
92hatchattack
Suspension & Brakes
May 26, 2006 05:15 PM
KiNG $h!t
Aug 24, 2004 10:14 AM
