Problem with headlights, tail lights, dash lights... What could it be?
Old Dec 1, 2004 | 02:20 PM
bboyoxygen's Avatar
Default Problem with headlights, tail lights, dash lights... What could it be?
To make it short.. I turn my headlight switch to the parking light position. All lights are on except headlights. I turn it to the on position and my headlights turn on but every other light goes out (Dash, tails, corner lights).
Anyone know what it could be? I'm figuring it's a short somewhere... I just dont know where it could be.
Right now I get it to click in between on and the parking light notch and everything turns on... but I'd like to fix it. Also, my blinkers blink incredibly fast. I've checked all my bulbs and they are fine. Fuses are fine too.
Old Dec 1, 2004 | 02:48 PM
bboyoxygen's Avatar
Default Re: Problem with headlights, tail lights, dash lights... What could it be? (bboyoxygen)
Bump.. anyone?
Old Dec 1, 2004 | 02:49 PM
revvin9k's Avatar
My guess would be the switch, only a guess though. Any other advise for this guy?
Old Dec 1, 2004 | 03:09 PM
mattssi's Avatar
This is the first time i have heard of this particular malfunction. Did it all of a sudden start doing this, or has it done this since you have had the car? Is there any aftermarket wiring going on under the dash(e.g. aftermarket car alarm)?
Old Dec 1, 2004 | 03:18 PM
bboyoxygen's Avatar
Default Re: (mattssi)
It has done it ever since I got the car. I have a motor swap and I have an alarm installed. Those things have been done since I've owned the car though. Also there's this chip I have to plug in under the dash to start the car. That's been there since I got the car too.
Old Dec 1, 2004 | 03:34 PM
mattssi's Avatar
Default Re: (bboyoxygen)
Sounds like somewhere along the line, somebody fudged up your under dash wiring. I would start by removing everything aftermarket under there, and possibly re-installing it. Or take it to a professional to see if they can recognize any fubar wiring?
Old Dec 1, 2004 | 03:39 PM
slthatch's Avatar
NO WAY MAN my **** is doing the exact same thing it just started yesterday i have to check it out tomorrow but i figure that it is a relay, so i would say check all of your relays and if you do find out please let me know what it is cuz i dont want to take my **** apart
Modified by slthatch at 12:53 AM 12/2/2004
Old Dec 1, 2004 | 03:44 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (slthatch)
Fast flashing blinkers indicate a dead bulb or relay. Have someone hit the brakes for you and verify all your lights are working properly. And check function of all exterior bulbs. If everything appears fine, you might want to take a look at the relays.
Old Dec 1, 2004 | 05:40 PM
slthatch's Avatar
bump for any more ideas before both he and i tear our **** apart
Old Dec 2, 2004 | 03:56 AM
bboyoxygen's Avatar
Default Re: (jlacoy82)
Stupid q but where are the relays?
Old Dec 3, 2004 | 07:56 AM
slthatch's Avatar
could be under the dash or under the hood just depends on what kind of car, i heard it could also be the headlight switch
Old Dec 3, 2004 | 07:57 AM
bbarbulo's Avatar
I had this problem too, it was the relay. I took it apart and resoldered it, it's worked like gooooold ever since.
kerubin
Aug 21, 2012 09:26 AM
Vtec Civic 93
Jan 5, 2011 09:28 AM
suspendedHatch
Mar 15, 2006 10:48 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
VTEC
Jul 2, 2002 12:37 PM
