Broke volve cover bolt!! :(
Old Dec 1, 2004 | 01:17 PM
doublethink's Avatar
Default Broke valve cover bolt!! :(
Not one of the 4 main in the middle, but one of the outside 4 on my b16 broke off.
How do I fix this???
Please help me out.
Old Dec 1, 2004 | 01:19 PM
Mr_CRX's Avatar
Default Re: Broke valve cover bolt!! :( (doublethink)
Is any of it sticking out of the head still? or did it break off down inside where it threads in?
If any of it is sticking out, try to grab it with some vise-grips or something and then unscrew it. I had this happen on a fuel rail stud/nut.
Old Dec 1, 2004 | 01:25 PM
Default Re: Broke valve cover bolt!! :( (Mr_CRX)
so what type of bolt is this then?
how do you screw this in when its new for example?
In the image it appears to be the screws i have highlighted with orange boxes.
Old Dec 1, 2004 | 01:30 PM
drdisco69's Avatar
The studs have a 10mm nut machined in them, just turn with a wrench. Take off the valve cover, remove the broken one, and put the new one in. If it broke off at the base, you may have to use an E-Z Out, screw extractor, or whatever you want to call it.
Old Dec 1, 2004 | 01:41 PM
Default Re: Broke valve cover bolt!! :( (drdisco69)
i see!! ill take the cover off again and do that, since it broke above that machined nut, i just havnt taken the cover off again to look yet....
where can i get one of these, autozone you think? dealer?
are their afftermarket replacments for these?
thanks for your help guys!
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The studs have a 10mm nut machined in them, just turn with a wrench. Take off the valve cover, remove the broken one, and put the new one in. If it broke off at the base, you may have to use an E-Z Out, screw extractor, or whatever you want to call it. </TD></TR></TABLE>
worked wonders for me when i had broke off a valve cover bolt also
Old Dec 1, 2004 | 01:45 PM
Default Re: Broke valve cover bolt!! :( (b2o-vtec)
right but whats the thing called, its not the head studs i know that, since those go down and hold the head to the block.
valve cover bolts?
Old Dec 1, 2004 | 01:57 PM
CRX_Control's Avatar
tell honda to print you a picture and you point it out to them.
Old Dec 1, 2004 | 02:01 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Default Re: Broke valve cover bolt!! :( (CRX_Control)
yea theyll have that picture on the computer when they are looking for the part u are describing
Old Dec 1, 2004 | 02:11 PM
drdisco69's Avatar
Valve cover stud. Go to a dealer, autozone probably doesn't carry them. I've never seen an aftermarket replacement, it's not really a stressed part.
Old Dec 1, 2004 | 02:14 PM
try the junkyard first , i broke mine a while back and the stud was like 8$
Old Dec 1, 2004 | 03:09 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">try the junkyard first , i broke mine a while back and the stud was like 8$</TD></TR></TABLE>
I got mine for the same price at Honda...
Old Dec 1, 2004 | 04:58 PM
T--Rex's Avatar
Default Re: Broke valve cover bolt!! :( (Smokinsax)
Happened to me too, just went to dealer and explaned the part. They found what i was looking for and i was on my way.
ryanangelo212
Oct 27, 2010 08:02 PM
DC206R
Feb 23, 2009 09:38 AM
00ekcoupe
37
Sep 5, 2005 06:15 PM
rayscar
Oct 11, 2004 10:34 AM
Qwikrex
Nov 17, 2002 08:42 PM
