Unorthodox Ultra R Underdrive Race Crank Pulley for 88-91 Si/CRX
Old Dec 31, 2001 | 10:26 AM
Todd00's Avatar
I said I don't want a title!
Default Unorthodox Ultra R Underdrive Race Crank Pulley for 88-91 Si/CRX
Has anyone ever tried one of these? Any gains to be had? Since I'm taking my a/c off, I figured I'll only need the alt. driven.
I know there is the myth about the oem crank pulley balancing the engine, but how are the D series? I think they are internally balanced, correct?
Old Dec 31, 2001 | 03:36 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Unorthodox Ultra R Underdrive Race Crank Pulley for 88-91 Si/CRX (Todd00)
The crank pulley does NOT balance the motor, but rids of bearing pounding forces on a long stroke D16 motor.
Old Dec 31, 2001 | 09:49 PM
Todd00's Avatar
Default Re: Unorthodox Ultra R Underdrive Race Crank Pulley for 88-91 Si/CRX (Mista Bone)
So I shouldn't have any problems then if I install the unorthodox pulley, correct? My a6 must stay internally stock for class rules.
Old Jan 1, 2002 | 09:09 AM
eg6ajk's Avatar
why not get a stock HF or VX pulley which only has an alternator option, much cheaper and its got a harmonic balancer build in so no problem should arise
Old Jan 1, 2002 | 09:56 AM
seeweed's Avatar
i have a polished one for sale
used for 2 weeks
email me
bundick@home.com
Old Jan 1, 2002 | 01:18 PM
Mista Bone's Avatar
D Tranny Guru
but you will have problems.......
Old Jan 1, 2002 | 01:26 PM
mini-cRx's Avatar
why would he have problems my boy put complete pulley set and he has no problems
Old Jan 1, 2002 | 03:41 PM
Todd00's Avatar
See, now I'm lost on what to do. My R has been running pulleys for the past year and a half and I've been ok so far. What will the lighter (but balanced) unortho. unit do to the motor that's so bad? If the engine is internally balanced, then the dampener (rubber isolation layer) on the stock honda is only there to quiet the accessories down and not balance the engine, correct?
In theory, disconnecting the p/s belt on a stock pulley would cause the same amount of harm because you'd be changing things up, so to speak.
Old Jan 1, 2002 | 03:55 PM
solorexer's Avatar
Hey Todd,
My car ran fine this year with an ASP underdrive pulley. I'm not sure how it compares to the Unorthodox pulley, though. I guess I'll find out for sure here in a couple weeks when I pull the motor out of the black car. .040 over next year
Old Jan 1, 2002 | 06:30 PM
Mista Bone's Avatar
D Tranny Guru
B motors don't have a dampen pulley.
A inline 4 cylinder is the WORST motor, it will beat itself apart.
I'd give you a link, but ENDYN BBS is down.
Old Jan 1, 2002 | 06:33 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Unorthodox Ultra R Underdrive Race Crank Pulley for 88-91 Si/CRX (solorexer)
Fred, guess I'll know to change my numbers before coming to Columbus for a autox event. I ran 13 CSP on my last set of numbers.
But that was almost 2 years ago!
billard
May 20, 2011 10:05 PM
bretts_crx
Jan 30, 2006 09:51 AM
BBY98EX
Jan 30, 2005 03:04 PM
