Rear Motor Mount
Old Dec 1, 2004 | 11:05 AM
pumafeet10's Avatar
Default Rear Motor Mount
Has Anyone had their rear motor mount on a 96 automatice tranny go bad or have a really bad vibration when ideling. I think that mine has gone bad and not sure what to do or how to check . what tools might i need to make a proper diagnosis. The mount seems to move a good amout i can hear something hitting or the mount moving a great deal not sure but what do i check?
Old Dec 1, 2004 | 12:15 PM
smooth95's Avatar
I have not had that problem yet
Old Dec 1, 2004 | 08:48 PM
pumafeet10's Avatar
Default Re: (smooth95)
great well that helps me ...Does anyone out there actually have anything that can help me out here???
Old Dec 1, 2004 | 10:00 PM
TeknoGroover's Avatar
Default Re: Rear Motor Mount (pumafeet10)
I had a very rough idle (still do unfortunately) but I took it into the dealer and they said it was my motor mount--it broke. I have a 97 though. F22B2. It fixed the bad idle for a while, so maybe I have another one or more broken?
Old Dec 8, 2004 | 07:53 PM
SCcorolla's Avatar
Old Dec 8, 2004 | 10:03 PM
j00ngyang's Avatar
i think u got the same problem i had...
not sure but maybe the advice other people gave me could be somewhat of a help to you.
Mine still shakes while idling...
any ways here's a link
http://board.accordtuner.com/s...pp=15
Old Dec 9, 2004 | 05:33 AM
JimBlake's Avatar
Default Re: Rear Motor Mount (dohcvtecguy)
Auto tranny Accord for some range of years have a vacuum-operated rear engine mount. It's supposed to get real soft when idling in gear, then harden up when you drive off. You need a MityVac, multi-meter, & a couple jumper wires to really troubleshoot it. Plus a Helm manual for the procedure.
For yuks, you can find the vacuum hose that goes down along the firewall, to the mount itself. Take it off the solenoid valve, then use the MityVac to apply & release the vacuum. Do this while someone's holding the brakes, car idling, in gear. It's supposed to make a big difference in how much vibration you feel.
If that part's OK, then you'll need a manual for whether the solenoid valve is normally open or normally closed or whatever...
silver accord
Nov 15, 2012 10:25 AM
5thGeneration
Aug 19, 2008 03:56 AM
emmaturecb7
Jan 10, 2008 04:56 PM
x8086x
Jun 7, 2003 03:57 PM
Ideal
Aug 2, 2002 02:08 PM
