What gauge for sunroof plug?
Well, it's time to take the sunroof out of my project
I would like the car to be both legal for NASA & SCCA, so I decided to go with the steel route. The SCCA rules state that the plug must be of the same material & thickness of the original roof. I was going to use 16 gauge steel, but I think this might be thinner than the original body panels (I heard a rumor that body panels are 22 gauge)
What gauge steel have you guys used?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MMsportsRexSi »</TD></TR><TR><TD CLASS="quote">16 gauge is thicker than 22</TD></TR></TABLE>
its the opposite way around. 16 ga is thicker then 22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">
its the opposite way around. 16 ga is thicker then 22</TD></TR></TABLE>
So what is it? Then or Than, gauge or ga? Other than that, I for the life of me can't see what you two are saying differently here. I agree with one of you I think
my english is the product of fairfax county public schools + spell check... my metal experience is 2.5 years after college in sheet metal fabrication.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie »</TD></TR><TR><TD CLASS="quote">why does the sunroof plug has to be the same material? I thought composite is legal?</TD></TR></TABLE>
It is for HC, but for SCCA you need steel
Your best and probably least expensive method would be to find the same car in a junk yard and cut the roof off and then fasten this to the race car in the shape you want. If you try a flat sheet, it may not contour as well to the rest of the roof.
I believe if the car has a metal sunroof, you can leave it in as long as you 'adequately retain' it in the roof.
I used metal from a dented hood I had. It's the original red hood from my car, so it's the same colour too. I then used red vinyl to cover the "seam" and rivets. Cheap, safe and it looks pretty good.
Obviously, I took out the support frame from the hood, using just the sheet metal.
