More o2 Sensor help needed.
Old Dec 1, 2004 | 07:40 AM
3WL's Avatar
3WL
Default More o2 Sensor help needed.
Hey all, I'm back w/more o2 sensor problems. Bear with me, I don't know sh*t about this stuff.
The code retrieved for my check engine light was P0133
The part I need is an o2 sensor OEM part #36531-p5m-014
The part costs about $300. Would I be ok buying a cheaper part?
Is there a diagram I can look at to see where exactly the part goes?
Thanks very much in advance.
Old Dec 1, 2004 | 08:32 AM
Filthy Focker!'s Avatar
Default Re: More o2 Sensor help needed. (3WL)
What do you mean by cheaper part? What is holding you back from going to autozone or something like that for the part.
fs
Old Dec 1, 2004 | 10:25 AM
b16h22a's Avatar
it goes in just like a spark plug. screw it in and connect the wire
Old Dec 1, 2004 | 07:38 PM
Prolink's Avatar
P133- primary O2 Sensor problem.
Located before the cat. Since your in VA, call a place called Olympus Auto Parts. You need to know the year, make , model, engine size, and if it is federal or california emissions.(check under the hood and look for a with stick.) If you need more help send me a PM
boynblue
12
Sep 13, 2008 09:28 AM
'96typeR
15
May 17, 2008 11:13 AM
moosepoop21
May 10, 2007 12:30 PM
rdeezy25
May 16, 2005 12:31 PM
hecktabite
Apr 28, 2002 10:14 PM
