D16Z6 Build up comments please
Alright guys I've spent about 3 months searching and reading, as any good H-T member should do, and this is the set up I will be going for this coming summer/fall 2005 (got save up money). This set up will be in a 94 civic ex. Here ya go. (comments welcome but plz no convo about b swap)(might go FI down the road, some stuff prep for that just in case)
EDIT
So what do you guys think. cost of all new parts I'm looking at 5-6k
(internals, with exception of crank, and injectors will be new, but everything else i'll try to find used) thanks for comments
Modified by 94exguy at 8:48 AM 12/1/2004
Modified by 94exguy at 9:00 PM 1/3/2005
EDIT
i have heard good things about the skunk 2 intake mani. Some say they have had i problem with fitment issues though. good luck on the build i'm planning on building up a z6 as well.
honda pm3 pistons. flat top piston that will bump your compression significantly. flat top pistons are also the most efficient piston design known to man.
OEM rings are quite good.
get the crank lightened, balanced, and micro-polished.
shot peen the oem rods...they are actually good for 300hp.
p7p the head, but get a 5 angle valve job.
jg engine dynamics camshaft 85vt80.
endyn cam sprocket.
obd-0 injectors.
VRD ecu w/ vtec controller.
jg engine dynamics TB.
anything but a skunk2 IM.
yonaka coilovers.
extra...have the cylinder walls finished with a plateau hone so you can run a tighter piston-to-wall clearance. get a meziere electric water pump and run a dummy.
stay away from nos...its no good for an engine.
endyn cam sprocket.
obd-0 injectors.
yonaka coilovers.
I'll look into the pm3 pistons and i was planning on doing all that to the crank just wasn't sure yet. I gonna stick with eagle rods, just feel better once im boostin, but turbo is gonna wait until around until 06 when i graduate hs. I'll make sure to stay away from skunk2 and nos. Thanks for the advise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94exguy »</TD></TR><TR><TD CLASS="quote">I'll look into the pm3 pistons and i was planning on doing all that to the crank just wasn't sure yet. I gonna stick with eagle rods, just feel better once im boostin, but turbo is gonna wait until around until 06 when i graduate hs. I'll make sure to stay away from skunk2 and nos. Thanks for the advise
ya .. i would go with atleast eagle rods ... i wouldnt stick with stock if planing to make 250 hp or more ...
</TD></TR></TABLE>ya .. i would go with atleast eagle rods ... i wouldnt stick with stock if planing to make 250 hp or more ...
Alright thanks thanks alot guys here is modified setup
Stock crank, lightened, balanced, and micro-polished
CP pistons 9:5:1
OEM ring set
Eagle rods
Fully built head
Zex 59300 cam
AEM cam gear
APR headstuds
ACL bearings
Walbro 225 fpump
RC 550cc sat inj
AEM fpr
*unsure brand* fuel pressure gauge (used)
MSD 8.5mm wires
Act clutch
TB Bore out stock
Port stick IM to matck TB and head
Custom 2.5" exhuast (magnaflow muffler and cat)
Omni power coilovers and chamber kit
T3/T04
5" johnnyracecar FMIC
Greddt type s BOV
Tail 38mm W/G
2.5" charge pipes
Uberdata
Greddy Profec boost controller
some type of Wideband
Modified by 94exguy at 12:23 AM 1/3/2005
CP pistons 9:5:1
OEM ring set
Eagle rods
Fully built head
Zex 59300 cam
AEM cam gear
APR headstuds
ACL bearings
Walbro 225 fpump
RC 550cc sat inj
AEM fpr
MSD 8.5mm wires
Act clutch
TB Bore out stock
T3/T04
Greddt type s BOV
Tail 38mm W/G
2.5" charge pipes
Uberdata
here's some pictures of D16 blocks we've put together.
Here's a D16A6 block with P29 pistons.
Our Exospeed Stage 1 D16 block package.
Our Exospeed Stage 4 D16 Block Package with Arias High compression pistons.
Fully built head
Zex 59300 cam
AEM cam gear
APR headstuds
Walbro 225 fpump
RC 550cc sat inj
AEM fpr
B/M fuel pressure gauge
MSD 8.5mm wires
Act extreme clutch
Custom 2.5" turbo-back exhuast (magnaflow muffler)
T3
6" johnnyracecar FMIC
Greddy type rs BOV
Tial 38mm W/G
2.5" charge pipes
Uberdata
PLX-300
New Set-up Decided to go w/ boost thanks all of you guys for the help
Modified by 94exguy at 12:20 PM 3/8/2005
Zex 59300 cam
AEM cam gear
APR headstuds
Walbro 225 fpump
RC 550cc sat inj
AEM fpr
MSD 8.5mm wires
Act extreme clutch
T3
Greddy type rs BOV
Tial 38mm W/G
2.5" charge pipes
Uberdata
PLX-300
