obdo to obd1
Old Dec 1, 2004 | 01:17 AM
blackcomet's Avatar
Default obdo to obd1
dont know much about ecus, so i really need answers to this question...i have obdo-pwo ecu for a b16 that is no good...i am wondering if it is possible to run an ecu from a newer obd1 b16..i think a p28 or p30 not sure...is there anyway to doing this ? ... and also how much would it cost or should i just buy a pr3 ecu....thanks in advance...
Old Dec 1, 2004 | 01:37 AM
Magick211's Avatar
Default Re: obdo to obd1 (blackcomet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcomet &raquo;</TD></TR><TR><TD CLASS="quote">dont know much about ecus, so i really need answers to this question...i have obdo-pwo ecu for a b16 that is no good...i am wondering if it is possible to run an ecu from a newer obd1 b16..i think a p28 or p30 not sure...is there anyway to doing this ? ... and also how much would it cost or should i just buy a pr3 ecu....thanks in advance...
First off the easiest way to go obd is with a jumper harness. You will need that, obd1 distributor,obd1 ecu, and maybe injectors.
The p28 although it is a obd1 ecu it is for sohc vtec but it can be chipped to run a b16a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and also how much would it cost or should i just buy a pr3 ecu....thanks in advance...
What pr3 ecu are you talking about? non obd or obd1, if you are refering to non obd then 50-100 on ebay.
Old Dec 1, 2004 | 02:25 AM
slate13530's Avatar
Default Re: obdo to obd1 (Magick211)
Don't mean to hijack this thread, but Magick where wouild I be able to locate one of them jumper harnesses?
Old Dec 1, 2004 | 03:09 AM
Magick211's Avatar
Default Re: obdo to obd1 (slate13530)
Contact bown90hatch he is here on the board and he makes a good harness.
also you can try theese companys they make them
http://jkobdconversionharness.....html
http://www.jdmshit.com/ecu/index.html
also boomslang makes one but i dont have the link to the site
Old Dec 1, 2004 | 10:29 AM
blackcomet's Avatar
when changing distributors is the obd1 legs going to fit or do i need to chop one off. hmm...seems like its cheaper to just buy an obd0 pr3 ecu...
Old Dec 1, 2004 | 12:24 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcomet &raquo;</TD></TR><TR><TD CLASS="quote">when changing distributors is the obd1 legs going to fit or do i need to chop one off. hmm...seems like its cheaper to just buy an obd0 pr3 ecu...</TD></TR></TABLE>
I have a 93 GSR obd1 distributor on a 1st gen B16A, it fits perfect. Not sure about newer distributors fitting on the 1st gen engines.
Old Dec 1, 2004 | 02:39 PM
fast90hatch's Avatar
Default Re: obdo to obd1 (Deetz)
wait..... are all PR3 ecu's obd0???? cuz i was looking at a 92-93 integra motor, trans combo. and it was a PR3 ecu.... i thought they never made obd0 after 91??? can someone clear this up.. don't mean to jump in.
Old Dec 1, 2004 | 02:55 PM
cursED's Avatar
Default Re: obdo to obd1 (fast90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast90hatch &raquo;</TD></TR><TR><TD CLASS="quote">wait..... are all PR3 ecu's obd0???? cuz i was looking at a 92-93 integra motor, trans combo. and it was a PR3 ecu.... i thought they never made obd0 after 91??? can someone clear this up.. don't mean to jump in.</TD></TR></TABLE>
There is also an OBD-1 PR3 ECU, along with the OBD-0 PR3.
Old Dec 1, 2004 | 03:18 PM
Default Re: obdo to obd1 (cursED)
ok, can that PR3 OBD1 ecu be made to work on a B16A DX with a motor swap?????
sorry forgot to add the car is a 1990
Modified by fast90hatch at 4:57 PM 12/1/2004
Old Dec 1, 2004 | 03:23 PM
Deetz's Avatar
Crazy Honda Guy
I have a obd1 pr3 in my 89 CRX. It can be programed to run any b series engine.
Old Dec 1, 2004 | 03:59 PM
Default Re: (Deetz)
cool thanks??? how much of a pain in the *** was it to switch your car to a OBD1.... sorry for butting in again.. this will be my last reply.
Old Dec 1, 2004 | 07:33 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (fast90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast90hatch &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks??? how much of a pain in the *** was it to switch your car to a OBD1.... sorry for butting in again.. this will be my last reply.</TD></TR></TABLE>
Well, lets see, the harness is plug and play between the obd1 ecu and the under dash harness, plus about 6 or 7 wires that come off the pig tail that are need for the 4 wire o2 sensor, knock sensor, ground, and vtec solinoid. Its not hard at all!
The injectors are also easy, giving you the choice to remain using a resistor box and non obd injectors, or removing the resistor, solding the injectors wires together and using obd1 models.
Deetz
rockinthe94LS
Aug 26, 2008 06:25 PM
blackie
Jul 10, 2005 03:38 PM
asocallocal
May 30, 2005 10:11 PM
89silverb16crx
15
Apr 14, 2004 10:02 PM
