failed emissions...too rich..why?
Old Nov 30, 2004 | 11:04 PM
icpmatias's Avatar
Default failed emissions...too rich..why?
okay so i went to take my emissions test in my 2000 gsr and right when i get there, my check engine light comes on, so of course i fail. it said "system too rich". how do i fix this? the car is stock other than bolt ons, the only fuel system mod is a high-flow pump because i used to have a turbo before i blew the motor. can this be causing the car to run rich?
the check engine light only comes on once in a while, for maybe a day or two at a time, then goes away for a while; and when it's on the car idles high. does that mean it's only running rich some of the time, not always?
please help, i have until january to fix it. thanks.
Old Nov 30, 2004 | 11:13 PM
Sack Master's Avatar
Default Re: failed emissions...too rich..why? (icpmatias)
If your fuel pressure is sitting at 60 psi you better believe your car will be running rich.
Old Dec 1, 2004 | 08:43 AM
icpmatias's Avatar
Default Re: failed emissions...too rich..why? (Sack Master)
why would it be at 60 psi?
Old Dec 1, 2004 | 09:00 AM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
I'm getting rid of my DA. It won't pass emissions for **** and I'm not spending any more money on it.
Old Dec 1, 2004 | 12:02 PM
breyton's Avatar
Default Re: failed emissions...too rich..why? (acuracrombie82)
got the same prob with ma 95 teg, my engine light doesnt come on, dont know if its jus a busted fuse or light, another would be my exhaust, is it true changing my catconverter will help me pass smog test?????
Old Dec 1, 2004 | 12:08 PM
Racermech's Avatar
Default Re: failed emissions...too rich..why? (breyton)
When the CEL comes on have you ever pulled the code?? If not you might want to check now jsut to see if it will throw a code even with the CEL off. Could be an air leak from the header before the O2 sensor causing it to push more fuel.
E J
Jun 9, 2016 10:47 PM
CrxChicken
May 28, 2015 06:54 PM
sykotic
Nov 17, 2004 10:00 PM
Cyrio
Aug 22, 2002 07:57 AM
RaVAGE00
Apr 13, 2002 02:34 PM
