9005 gold bulbs
Old Nov 30, 2004 | 09:01 PM
Spoon ITR's Avatar
Default 9005 gold bulbs
This may sound like a dumb question but, I was wondering how some of you manage to run the 9005 high beams whenever you want rather then using the high beams with the 9006's. Any info would help alot I would lvoe this mod on my gsr
Old Nov 30, 2004 | 09:09 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 9005 gold bulbs (JDMDC2GSR)
huh? what? you want to blind people all the time?
Old Nov 30, 2004 | 09:16 PM
Spoon ITR's Avatar
Default Re: 9005 gold bulbs (PatrickGSR94)
Here this is what I mean
https://honda-tech.com/gara...=2998
Old Nov 30, 2004 | 09:18 PM
Community Builder
it's a Canadian car, which has daytime running lamps (required on all Canadian vehicles), which runs the high beam headlights at reduced voltage whenever the car is on, and I believe when the parking brake is released.
Old Nov 30, 2004 | 09:21 PM
Spoon ITR's Avatar
I have seen these on US models though so thee has to be a way to run them to a switch or something? I was just curious as to how it was done I thought it looks sweet on alot of cars.
Old Dec 1, 2004 | 05:28 AM
Community Builder
What you saw was either a Canadian-spec car (sometimes people in the Northern US have them), or it just had an aftermarket DRL circuit. They're easy to find and fairly inexpensive.
Old Dec 2, 2004 | 12:03 PM
rufridn's Avatar
how would i go about doing this?
Old Dec 2, 2004 | 12:09 PM
leechungsr's Avatar
I would run the 9005 in place of the 9006. Read up. There's plenty.
» Search Results
Your search for 9005 conversion returned 478 results.
» New Search
Old Dec 2, 2004 | 12:13 PM
Rory Breaker's Avatar
Default Re: 9005 gold bulbs (Lee Chun)
What hes trying to do is wire DRL in place of his high beams, Im assuming...nothing to do with the 9005 conversion.
I actually wouldnt mind doing this either....how would one do this?
Old Dec 2, 2004 | 01:13 PM
juicy.fn's Avatar
Default Re: 9005 gold bulbs (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">What hes trying to do is wire DRL in place of his high beams, Im assuming...nothing to do with the 9005 conversion.
I actually wouldnt mind doing this either....how would one do this?</TD></TR></TABLE>
yeah id like to know too.
Old Dec 2, 2004 | 02:17 PM
Community Builder
Um just buy an aftermarket DRL kit, I think it's pretty much a relay or relays and some other wiring stuff.
Old Dec 2, 2004 | 04:08 PM
Spoon ITR's Avatar
Default Re: (PatrickGSR94)
The way I want to do it is to put HIDS in the low beams then disconnect the high beams to run them to a switch with the gold bulbs
again, heres the link of what I want https://honda-tech.com/gara...=2998
Old Dec 2, 2004 | 05:24 PM
TunerN00b's Avatar
Default Re: (JDMDC2GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2GSR &raquo;</TD></TR><TR><TD CLASS="quote">The way I want to do it is to put HIDS in the low beams then disconnect the high beams to run them to a switch with the gold bulbs
again, heres the link of what I want https://honda-tech.com/gara...=2998</TD></TR></TABLE>
Please don't put HIDs in the halogen projectors. Do it right and retrofit HID projectors into the factory housings.
If you are going to add DRL with the high beams, they are not at full brightness. Please get a proper DRL kit, so you don't blind people. You can connect the kit to a switch instead of the ignition so they are on when you want them. Also, do not run DRL at night, they still point up and will blind people, even at lower power levels.
Old Dec 2, 2004 | 07:51 PM
Community Builder
Why would you want to disconnect the high beams? Just get a proper DRL kit to do it right and get the look you want and still have high beam functionality.
And don't think for a second that you don't need high beams with HID. WRONG! For one thing, HID in the stock projectors will not put out the light very far. Even with OEM HID projectors, if the cutoff is properly aimed so as to not blind other drivers, it won't put out enough light to see on those dark back roads and stuff. The fact that the cutoff is sharp only accentuates the contrast, making the dark unlit area seem even darker in comparison to the lit area. So you still need your high beams to light up those areas the low beam projectors can't reach, provided of course that other cars aren't coming towards you.
Old Dec 2, 2004 | 10:08 PM
pbizzlegsr's Avatar
where do you go about getting a drl kit and can you explain what needs to be done..?
Old Dec 3, 2004 | 04:58 AM
Community Builder
Default Re: (pbizzlegsr)
I dunno, JCWhitney, maybe summit racing, it's just wiring up a couple things and I'm sure it would come with instructions.
8dxhatchy8
Aug 1, 2010 08:41 PM
jdmCD695
Jun 27, 2008 09:15 AM
Spartan500
Sep 6, 2007 06:07 PM
92LudeSI
Mar 10, 2004 04:51 PM
paulyman
Apr 1, 2002 07:17 PM
