Specific Oil Pump install question
Heres the lowdown, suspected oil pump failure in 94 jdm h22. Going to check with oil pressure guage but just in case:
When removing and installing the balancer driven gear to i need to re apply molybdenum disulfide grease? Where in the hell do i find this stuff?
excerpt from helms
22." Apply molybdenum disulfide to the thrust surfaces of the balancer gears, as shown, before installing the balancer driven gear and the balancer gear case."
From my understanding, the gear needs to be taken off so the oil pump housing can be removed/installed.
Just wondering if anyone would even know something like this.
I will scan the pic in if need be. thanks in advance
excerpt from helms
Any autozone type store would have it. Regular grease would work too, and if you don't have either you can probably just put a few drops of oil on it. It will have oil flowing to it pretty soon after starting the engine.
VaporTrail
Sep 5, 2006 03:35 PM
