B.A.R sticker need advice
i have a 95 civic and am thinking of buying a 2000 usdm type r motor but my friend says i wont be able to get the bar sticker because it has to be a obd1 motor and that i have to have a 95 motor in it (ex: 95 gsr block) but i could put the type r head on it i need some advice
That is wrong... the motor has to have all the usdm smog equip., has to use a usdm ecu that matches the motor and has to be the same year as your car or newer... It does NOT have to be the same obd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NineTwoSi »</TD></TR><TR><TD CLASS="quote">That is wrong... the motor has to have all the usdm smog equip., has to use a usdm ecu that matches the motor and has to be the same year as your car or newer... It does NOT have to be the same obd.</TD></TR></TABLE>
to be more precise, your car can have a newer motor than the model year of the car itself. you need to run all the smog equipment of the motor. for example, if you want to BAR a 2000 it-r motor, you need to run the OBD2 P73 ECU and have a working diagnostic port, along with all the USDM smog equipment. its not terribly difficult to do, but not easy.
