Intake Manifold
Old Nov 30, 2004 | 06:37 PM
DShowers's Avatar
Default Intake Manifold
I just recently installed my Skunk 2 intake manifold on my GSR. I have the stock GSR ecu. I was wondering about the butterfly setting on the ecu? I already know that i got rid of that on the manifold but does it still try to engage at the set rpm or not. when driving it fells like it still surges at that rpm but I could be imagining it!
thanks for any help you give me!
Old Nov 30, 2004 | 07:26 PM
robtec's Avatar
Default Re: Intake Manifold (DShowers)
the butterfly opens by vacum not by an ecu signal,and the surge at that rpm is called vtec
Old Nov 30, 2004 | 07:55 PM
DShowers's Avatar
Default Re: Intake Manifold (robtec)
haha I know that but I meant after Vtec!
Old Nov 30, 2004 | 09:37 PM
mtber's Avatar
It shouldnt "surge".
Check your fuel pressure, make sure your fuel pump is keeping up w/ your motor etc..
Old Dec 1, 2004 | 05:13 PM
robtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DShowers &raquo;</TD></TR><TR><TD CLASS="quote">haha I know that but I meant after Vtec! </TD></TR></TABLE>
he he,seriously there should be no problems when changing the im on a b18c1 and still use the p72 ecu,i've done it and have no probs
Old Dec 1, 2004 | 06:03 PM
mtber's Avatar
You should consider a chipped skunk2 ecu for your setup. You will see a big increase in midrange power & possibly eliminate your "surge" issue.
diggy
Jan 2, 2008 08:02 PM
polishedturd
Dec 4, 2007 08:14 PM
DShowers
Nov 30, 2004 06:05 PM
jdhealy
Jun 6, 2003 03:34 PM
GSR -97
Nov 23, 2001 09:01 PM
