90 Civic SI - Brake Light won't go off
When I baught the car the light didn't stay on all the time. It use to come on only if I left the E-brake up. but after about a month I relized that it was staying on all the time. I thought it might be the little electronic switch by the E-brake might be stuck but wasn't. I checked the brake fluid level and full some im stumped...
If you own a phillips head screw-driver. The one that looks like an X on the end, and has a handle at the other end, remove the screws holding your center console in. The center console is the thing between the 2 front seats. Find the momentary switch that activates when you raise your e-brake handle, and determine if the switch is stuck in the closed position. If the switch is just fucked and you cant get the light off even after playing with that, unplug the harness, the light will go off. Just dont forget when you set your brake, smoking pads/drums smell like ***. Or just do like me and set your ebrake every time you park the car! 5 speed madness j0!!
