Engine Troubles, please help
Old Nov 30, 2004 | 02:24 PM
Streets_of_Fire's Avatar
Default Engine Troubles, please help
greetings!! well in our 00 civic with CVT and d16 motor, the car is throwing and manufacturing air/fuel metering code when the car runs over 4500 rpm, the car stalls and wont rev past 4500 anymore, ??
code p1259
Old Nov 30, 2004 | 04:39 PM
86si's Avatar
Default Re: Engine Troubles, please help (Streets_of_Fire)
vtec system malfunction,sounds like the switch is bad pr oly stuck
Old Nov 30, 2004 | 05:16 PM
Default Re: Engine Troubles, please help (86si)
thanks for the heads up, what/where exactly is the vtec switch and how would i check it?? thanks!!
Old Nov 30, 2004 | 05:54 PM
dohcter g's Avatar
I think it uses knock sensor on the back on the engine near the oil filter to activate vtec. The Vtec sol is on the Transmission side of the head. If your timing is wrong the car will go into safe mode and not rev above 4.5k. Good Luck!!!
Old Nov 30, 2004 | 05:58 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: Engine Troubles, please help (dohcter g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">I think it uses knock sensor on the back on the engine near the oil filter to activate vtec.</TD></TR></TABLE>
No
Old Nov 30, 2004 | 06:01 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: Engine Troubles, please help (1320project.com)
Try to remove the Vtec solenoid and see if the screen on the gasket is clogged. That sometimes happens to engines that havent been taken care of. If its clogged, clean it and reset the ECU.
Old Nov 30, 2004 | 06:06 PM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320project.com &raquo;</TD></TR><TR><TD CLASS="quote">
No </TD></TR></TABLE>
Then what acivates Vtec then...........I don't need Vtec, LOL...hee, hee!!!
Old Nov 30, 2004 | 06:09 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Oil pressure and a solenoid. Knock just senses detonation. Its more of a safety sensor. If the engine detonates, the ECU will not allow Vtec to activate, thus preventing engine damage. The reason LSs dont have knock sensors is because the compression is so low and cam lift isnt very big so there isnt really a need for it.
Old Nov 30, 2004 | 06:15 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">If your timing is wrong the car will go into safe mode and not rev above 4.5k</TD></TR></TABLE>
This is also untrue.
And the ecu detecting knock does not disable vtec, it merely retards the timing a few degrees until the knock is gone. If it disabled vtec every time it detected a knock, you would be pissed at honda.
Old Nov 30, 2004 | 06:18 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: Engine Troubles, please help (drdisco69)
true..i was thinking about a knock code 23. good point......but its a sohc anyway so there isnt a knock sensor
Old Nov 30, 2004 | 06:23 PM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
BS!!!!!
I know what a Knock sensors soul purpose is for. If a cam gear slips the engine will go in safe mode. If you don't believe me than you have never seen it happen. I work on all the guys cars around here and one day one of them brought me their car and said is not going above 4 to 5k rpms. I noticed first thing that his cam gear had slipped. This was a 1995 LS motor. Lucky bastard did not hit the valves and I put it back at TDC and the car was fine.
Ha, Ha, Ha, you rookies kill me every time.
Old Nov 30, 2004 | 06:25 PM
Mike@CCT's Avatar
Formerly Mike@TSR
LSs dont have knock sensors. the thing probably wouldnt rev because the cam timing was so retarded.
Talk about rookie
Old Nov 30, 2004 | 06:29 PM
dohcter g's Avatar
This is not about Knock sensors any more, wake up!
Old Nov 30, 2004 | 06:35 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Stuff changes quickly in your jumble of words huh?
So the cam gear slipped maybe?
What did you do to the 1995 LS to keep the timing belt from slipping again?
Old Nov 30, 2004 | 06:38 PM
dohcter g's Avatar
Just messin with ya bro!! He only had one bolt out of six left in it. They all vibrated out because he did not torque them properly. I just replaced the bolts and sent him on his way.
Old Nov 30, 2004 | 06:51 PM
Mike@CCT's Avatar
Formerly Mike@TSR
wow. ok cool.
Old Nov 30, 2004 | 06:54 PM
drdisco69's Avatar
I promise the ecu had nothing to do with the car not revving. There's no "cam gear slip sensor", it just goes off what it sees in the distributor sensors. Jumping a tooth often just ***** the timing up enough to where it doesn't make any more power. Did it go "wapwapwap" like a normal revlimiter, or just run out of power?
Lets be careful about who we call rookies, all this vtec talk from a guy with an ls...
markthomas
May 29, 2014 07:33 AM
ntoxicatedtigah
Jun 24, 2009 02:56 PM
numberone
16
Nov 27, 2006 06:43 PM
pr3crx
Feb 5, 2004 10:04 AM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
