(searched) When I hit vtec-check engine-no more vtec
That's right! When I hit vtec at 5500, I get a check engine and no more vtec. I do not get a check engine light unless I hit vtec. After I turn the car off, the check engine light goes away and there is no code in the computer!"Son of a Bitch" Tell me what you think even if it hurts! Thanks.
Re: (searched) When I hit vtec-check engine-no more vtec (numberone)
have you tried to check the code yet. if i'm not mistaken, if you jump the connector, you should still get a code. My guess is it's probably one of the vtec codes?!?
Re: (searched) When I hit vtec-check engine-no more vtec (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head »</TD></TR><TR><TD CLASS="quote">knock sensor?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItR_98 »</TD></TR><TR><TD CLASS="quote">have you checked your oil level?? had this happen to me in my gsr once.. turns out i was just low on oil. changed the oil and replaced the oil pan gasket and all was well. </TD></TR></TABLE> Yes I checked my oil. If it was a knock sensor, the check engine light and code would stay on the computer until it was cleared.
do you have an oil pressure gauge? if so what psi are you hitting when vtec engages?
there is also a screen behind the vtec solenoid that can become clogged.
Re: (searched) When I hit vtec-check engine-no more vtec (dohcdelsol93)
[QUOTE=dohcdelsol93]do you have an oil pressure gauge? if so what psi are you hitting when vtec engages?
there is also a screen behind the vtec solenoid that can become clogged.[/QUOTE ]I already cleaned the screen on the vtec solenoid. I do not have a pressure gauge, but you have a good idea. I'll try it. Thanks.
Sounds like you are having VSS issues. once that signal is broken, at wot, a code pops up and bye bye vtec.
Re: (searched) When I hit vtec-check engine-no more vtec (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">Sounds like you are having VSS issues. once that signal is broken, at wot, a code pops up and bye bye vtec.</TD></TR></TABLE> It's Chris in sac! Call me and explain how I can fix this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">i lost your info, and justins. lol, one of you gotta call me first
</TD></TR></TABLE> 10-4!
You can just check the code immediately after this happens. Next time it happens, just pull over as soon as you can and jump the connector.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numberone »</TD></TR><TR><TD CLASS="quote">When I hit vtec-check engine-no more vtec</TD></TR></TABLE>
You ran out of Vtec. You need to refuel.
Re: (searched) When I hit vtec-check engine-no more vtec (BauleyCivic)
2000 si b16 obd2-obd1 jumper p28 skunk chip<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">
You ran out of Vtec. You need to refuel. </TD></TR></TABLE> Good one.
Modified by numberone at 11:16 AM 11/27/2006
...Code 21
He has tried a new vtec unit also.
hey Chris i was thinking...
Im a dumbass first of all ...VSS... lol.
I think this might be my fault. know anyone you can swap computers with, to rule out the possibility that its my ecu that's jacking up. i don't really think so, but its possibly. it does say chiped on the front of it. lol ...Justin.
need to check wiring. im thinkin that the solenoid is not getting signal.
36Chitownrunnin
06-17-2008 08:44 PM
Formula Racing
12-21-2005 05:51 PM
